Introduction: Illuminated Door Exit Switch.
Picture of Illuminated Door Exit Switch.
I wanted an easy to locate switch for my door solenoid lock. The original works but it's just not eye catching.
Step 1: Removing the Bland Switch.
Picture of Removing the Bland Switch.
I just plain cut the wiring off the old switch. I put it away in storage.
Step 2: Making a Hole for the New Switch.
Picture of Making a Hole for the New Switch.
The new pushbutton switch needed a 22mm hole in the mounting plate. I used a hole saw to make it.
Step 3: Wiring the New Switch.
Picture of Wiring the New Switch.
Using my soldering station I wired up the new switch. Sadly the hole I cut was a bit bigger than 22mm so I kept the lock nut in the front and a cable tie to keep it in place in the back.
Step 4: Completion!
Picture of Completion!
The new switch is led lighted and looks so much cooler!
About This Instructable
317views
3favorites
License:
Bio: As of April 2017 I have decided to no longer post on instructables. The fact that several of my published works have been removed without ... More »
More by Mjtrinihobby:External Light Sensor Night Light.Replacing a Toilet Tank Float Valve. How to Make Pig Feet Souse!
Add instructable to:
