Iluminated Huge Wooden Letters With "just Married Detector"
2,004
21
Posted
Introduction: Iluminated Huge Wooden Letters With "just Married Detector"
Inspired by the Instructable Huge wooden letters by Cactus workshop , I have prepared these letters for my wedding with Julia to be held next July 2 (coincidentally the initials match those of Cactus ) , my tools are not ideal for professional woodworking so I had to throw a lot of imagination.
To not overtake surprise guests to leave the final photos after the celebration, but since the contest ends before, there goes our Instructable , hope you like it .
The letters are made with MDF 10mm , R and J have a size of 1200 mm and 800 mm for the & and a thickness of 150 mm , for tipografia have used " Corbel " in italics a clear type font , which favors both the reading as work on wood, to add the personal touch you have installed a detector of " just married " , which turns on or off the LEDs of each letter by proximity thereof, based on ..... that explains later :-)
----------------------------------------- Castellano ---------------------------------------
Inspirado en el Instructable de Huge wooden letters by Cactus workshop, he preparado estas letras para mi boda con Julia que se celebrará el próximo 2 de Julio ( casualmente las iniciales coinciden con las de Cactus ), mis herramientas no son las ideales para trabajos profesionales en madera, así que tuve que tirar mucho de imaginación.
Para no adelantar la sorpresa a los invitados dejamos las fotos finales para despues de la celebración, pero dado que el concurso finaliza antes, hay va nuestro Instructable, esperamos que os guste.
Las letras estan realizadas con MDF de 10mm, R y J tienen un tamaño de 1200 mm y de 800mm para el & y un grosor de 150mm, para la tipografia he utilizado "Corbel" en cursiva, una fuente clear type, que favorece tanto la lectura como el trabajo sobre la madera, para añadirle el toque personal le he instalado un detector de "recien casados", que enciende o apaga los led de cada letra según la próximidad de los mismos, basado en..... eso se explica más adelante :-)
Step 1: Cutting, Drilling, Volumizing , Painting ( 1) / Cortar, Taladrar, Dar Volumen, Pintar (1)
Draw , once we have prepared letters to set them in the MDF, as we have continuous plotter, Julia printed in A4 and later joined with a perfect result.
Cut, as easy as following the stroke , depending on the ability of each and its tools , you will need to make more cuts during the process , remember to join the two panels varien not among them.
Drilling, before removing the paper, remember to point out the marks , later to drill a layer of MDF, for this type of Led I use a 8.5mm drill .
Volumizing , this is beginning to take shape !! have previously prepared 140mm slats that serve to give volume, we glue and nailed along the perimeter , reinforced in curves and corners.
Painting (I) , a first coat of paint will help us to finish, performing it at this point will prevent the soiling Led paint .
Dibujar, una vez que tengamos las letras preparadas pasamos a fijarlas en el MDF, como no disponemos de plotter continuo, Julia imprimio en A4 y más tarde los unio, con un resultado perfecto.
Cortar, tan fácil como seguir el trazo, dependiendo de la habilidad de cada uno y de sus herramientas, será necesario hacer más cortes durante el proceso, recordad unir los dos paneles para que no se varien entre ellas.
Taladrar, antes de retirar el papel, recordar señalar las marcas, para posteriormente taladrar una capa de MDF, para este tipo de Led utilizo una broca de 8.5mm.
Dar volumen, esto ya empieza a coger forma ¡¡ previamente hemos preparado unos listones de 140mm que nos servirán para dar volumen, los encolamos y clavamos a lo largo del perimetro, reforzando en las curvas y esquinas.
Pintar(1), una primera mano de pintura nos ayudará para el acabado final, realizandolo en este punto evitaremos que los Led se ensucien de pintura.
Step 2: Led Install and Wire / Instalar Y Cablear Led
This type of LED is capable of delivering 1 watt of power, since we want the batteries can withstand as much as possible and the LEDs emit optimal light, we chose to reduce the current to 0.1A (100mA) for it connect in series 3 led and a resistance of 47ohm approx. and parallel unieremos many as we need.
Remember ¡¡ respect the polarity of the LED, otherwise it will not turn on, to know the polarity we look at the marks on the blades of each pole.
To power I used 12V 7.2Ah batteries recycled some old UPS (6 units), here are the calculations if need.
Notice technical part, it may cause drowsiness.
R= 57 Led / 3 =19 x0.1 A = 1.9Ah , 1x7Ah / 1.9Ah = 3.7h aprox.
& =52 Led /3 = 18 x0.1 A = 1.8Ah , 1x7Ah / 1.8Ah = 3.8h aprox.
J = 27 Led / 3 = 9 x0.1 A = 0.9Ah, 1x 7Ah / 0.9Ah = 7.7h aprox.
If we want to increase the autonomy, parallel connect as many batteries as needed.
Este tipo de led es capaz de suministrar 1 vatio de potencia, dado que queremos que las baterias aguanten lo máximo posible y los led emitan una luz óptima, optamos por reducir la intensidad a 0.1A (100mA) para ello conectaremos en serie, 3 led y una resistencia de 47ohm aprox. y unieremos en paralelo tantas como necesitemos.
Recordar¡¡ respetar la polaridad de los led, de lo contrario no encenderá, para conocer la polaridad nos fijaremos en las marcas realizadas sobre las palas de cada polo.
Para la alimentación he utilizado baterias 12V 7.2Ah recicladas de algún SAI antiguo(6 und), aqui van los cálculos por si los necesitaís.
Aviso parte técnica, puede causar somnolencia.
= Total Led / unidades por ramal x intensidad ramal = consumo Amperios hora / capacidad bateria = horas funcióna
Si deseamos aumentar la autonomia, conectaremos tantas baterias en paralelo como sea necesario.
Step 3: Design and Programming Arduino (just Married Detector ) / Diseño Y Programación Arduino (el Detector De Recien Casados)
The idea is that the LEDs of each letter are lit when staying near the right person, but it will not be influenced by the proximity of a guest, you should also turn off when stay away, also it has to be small so as not to occupy space bother.
To make the application, I rely on the transmission of a Ping to a receiver (installed in the letter &) every x seconds, I can play with a detection range by increasing or decreasing the transmission speed (faster lower range), the VirtualWire.h library for arduino is responsible for managing communications, and since we have free several PWM pins to give employ them or remove the lED light, the rest is to program the play of light you want.
La idea es que los led de cada letra se enciendan cuando permanezca cerca la persona correspondiente, pero que no se vea influido por la próximidad de algún invitado, tambien deberia apagarse cuando se alejen, además tiene que ser pequeño para no ocupar espacio molestar.
Aviso parte tecnica, puede causar somnolencia.
Para realizar la aplicación, me baso en la transmisión de una Ping hacia un receptor (instalado en la letra &) cada x segundos, además puedo jugar con la distancia de detección aumentando o disminuyendo la velocidad de transmisión (más velocidad menor alcance), la libreria VirtualWire.h para arduino es la encargada de manejar las comunicaciones, y ya que tenemos libres varios pines PWM los empleamos para dar o quitar luminosidad a los led, el resto es programar el juego de luces que deseemos.
Step 4: Close Volume, Paint (II) / Cerrar Volumen, Pintar (II)
Close the letters, I used 1 board MDF 1220 x 2440 x 3mm cut into plates x150mm 1220 and to work them to make the curves have two alternatives:
- "Professional" (as in the instructable Cactus) milling parts of the plate to gain flexibility, but we need good tools: '(
- The "we have no choice" (based on the manufacture of barrels) consisting of wet plates MDF until it has flexibility to adapt to the curve and wait for it to dry, the result is quite satisfactory, but somewhat slower .
Paint (II), a second coat of paint will come us well, taking special care with the front side with Led.
Cerrar las letras, he utilizado 1 tablero de MDF de 1220 x 2440 x 3mm cortado en placas de 1220 x150mm y poder trabajarlos, para realizar las curvas tenemos dos alternativas:
- la "profesional" ( como en el instructable de Cactus) fresando partes de la placa para adquirir flexibilidad, pero para ello necesitamos buenas herramientas :' (
- la "no nos queda más remedio" (basado en la fabricación de barricas ) que consiste en humedecer las placas de MDF hasta que adquiera flexibilidad, adaptarlo a la curva y esperar a que seque, el resultado es bastante satisfactorio, pero algo más lento.
Pintar (II), una segunda mano de pintura nos vendrá bien, teniendo especial cuidado con la cara frontal con los Led.
Step 5: Test, Retoques Finales.
Few remaining steps to finish our instructable finally ¡¡¡ .
Round, to improve the final appearance will round the edges of each letter , thus disimularemos the lined with 3mm MDF .
Batteries, the hole in each foot will serve to house the batteries, you previously prepared a support fixing them in the MDF, avoid thereby the battery shifting during transport of the letters , also in the case of J It will serve to move the center of gravity , preventing it from tipping over.
Ya quedan pocos pasos para terminar nuestro instructable, por fin ¡¡¡, que largo se me ha echo
Redondear, para mejorar el aspecto final redondearemos los cantos de cada letra, de esta forma disimularemos el forrado con el MDF de 3mm.
Baterias, el hueco en cada pie nos servirá para alojar las baterias, previamente habremos preparado un soporte de fijación de las mismas en el MDF, evitaremos con ello que las baterias se desplacen durante el transporte de las letras, además en el caso de la J nos servirá para mover el centro de gravedad, evitando que vuelque.
Step 6: Surprise
And only need to see the result, but first you have to surprise guests .
Ya solo falta ver el resultado, pero antes hay que sorprender a los invitados. ;-P
Step 7: Listado De Materiales
- 2x MDF 1.22 x2.44m x 10mm.
- 1x MDF 1.22 x2.44m x 3mm
- 150 x led smd 1W (136 und)
- 50 resistencias 47Ohm (45und)
- 2 x arduino nano clon (o similar)
- 1x arduino Leonardo
- 3x mosfet (stp16NF06)
- 2x Modulo RF433 Transmisor
- 1x Modulo RF 433 Emisor.
- 3x Bateria plomo 12v 7Ah ( recicladas ,utilice 6 para ampliar autonomia)
- 2x Pila 9V
- Cables varios
- 1kg pintura blanca
- Herramienta
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
This looks really cool. Also I think that it is awesome that you included instructions in two languages. That is the first time that I have seen that on this site.
thanks , we will come well to the Spanish-speaking community.
