The thin nature an flexibility of the gel makes it well-suited for incorporating into artworks. It's transparency gives some interesting possibilities... think light boxes or night lights (I did a multi-piece light installation with gel medium transfers as part of BFA work). The malleability makes it well suited for jewelry and other small craft projects.
This tutorial shows the basics - more the process than a final product - your imagination can take it from something simple into something amazing. There's almost an infinite number of applications across the arts and crafts spectrum.
And i realize the image of the BMW isn't the most artistically dynamic, but it works pretty well to show the process.
Step 1: Materials
- acrylic gel medium
- brush
- dish or tray
- water
- scissors (in case trimming is necessary)
- an image to transfer
notes on the gel:
the beauty of this technique lies in the nature of the acrylic - you can adjust and modify the gel to suit your needs... whether using retarder to increase smoothness, mixing in acrylic pigment, or even mixing in other materials (i've seen everything from gold flake to sand mixed into the acrylic gel). I use Liquitex's Gloss Heavy Gel Medium, but any clear acrylic medium works.
notes on the image:
Any image can be used for transfering, although some work significantly better than others. Uncoated magazines/newspapers work beautifully, but more coated photos/postcards/etc. may or may not transfer well - a color photo copy would be recommended to increase the probability of a successful transfer. Laser printed images work, but ink-jet prints generally don't work as well.
notes on the brush:
you can use any brush you'd line, whether bristle or foam. The different textures of the brushes will lay the gel medium down differently and will yield varied final products.
Step 2: Apply first coat of gel medium
Apply a thin coat of the acrylic gel medium with the brush, being careful to keep brush strokes smooth and even (unless you really want to build up the brush strokes and have them come through in the final product).
- Optional: If you wanted to add other acrylic media like pigments, or even other materials, it can be integrated in this step. in my example, I just stuck with pure gel for this go 'round.
Some people prefer to tape down their images (I've even heard of setting it in a glass pane with spray adhesive to ensure it remains flat) but I've personally never found the buckling of the paper with the moisture from the gel to be a significant problem.
Step 3: Wash your brush!
Wash the brush in warm running water after each application. Enough time for the coat to dry is enough for the brush to dry out as well. Not rinsing your brush will pretty much render the brush useless.
And just to be safe, I'd rinse it in a non-food prep sink, just to be safe. Acrylic isn't the healthiest stuff in the world (this would be a good point to mention it's not advisable to consume the gel medium either, even if it looks like sour cream).
Step 4: Continue applying coats of gel
Allow the second coat to fully dry again, turning clear, before applying the next coat.
Continue applying thin coats (and allowing for drying) until you have a fairly substantial layer of gel medium. Usually somewhere between 4 and 10 coats is ideal, depending on thickness of each application and desired final thickness.
Step 5: Allow the image to fully dry
Step 6: Soak the image
Trim the paper down to the gelled area, if necessary.
Fill a tray/dish/bucket with lukewarm water. too hot, and the acrylic is in danger of softening too much, too cold and dissolving the paper will be more difficult.
Soak for roughly 10 to 15 minutes, but not much longer or else the acrylic may over-soften.
- a note on trays: I'm using a small photo darkroom tray. I highly recommend picking up some darkroom trays for craft use, even if they'll never see a photo. They're made of a tough plastic (or sometimes metal) and hold up to tons of use. For this one, however, you could use pretty much anything... tupperware, a baking dish, even a stopped sink. Just keep food dishes separate from this project as acrylic medium isn't food-safe.
Step 7: Gently remove the softened paper from the gel
Gently rub the paper side to break up and dissolve the paper from the gel medium.
Be sure to keep working at the gel, getting all of the small paper fiber off of the back. There is usually a small layer left after scrubbing the initial layer off. If you take the time to remove every bit of fiber, the image will look noticeably cleaner/clearer. (see the close-up photo showing the difference).
You may need to empty the water if it gets too saturated with paper pulp.
Step 8: Dry the gel image
I usually place the gel images on either glass or plastic. Paper fibers have a tendency to stick. And as long as the gel hasn't dissolved/melted, there shouldn't be any issues with the gel sticking to glass or plastic.
Note that it's normal for the gel to still appear milky, and won't completely clear until dry.
Visit Our Store »
Go Pro Today »
Simply lay down the image on your canvas or other medium. Then spray the whole canvas with clear coat. Make multiple coats until the picture is level to the rest of the canvas. You can also buff out the clear coat to make it more level and flat.
Also to be considered is that most ink-jet inks are water soluble. This is why you want to use a fixer to prevent humidity in the air from causing the ink to mix with other inks, and also to protect the ink from drops of water. It's the same variety of issues that watercolor painters have had to deal with for centuries.
That said, you might try spraying the paper you are going to use with a fixative, printing to that, then waiting for the ink to dry before applying the acrylic gel medium. The waiting time may have to be more than the couple of minutes that you would normally wait as the ink should not be absorbed by the paper at all, and you will have to wait for the fluids in the ink to evaporate. You might have to do some test runs to see what that drying time is, then extend it based on the local humidity.
i'm definitely going to use this is my current piece. i'm a photographer/painter/sculptor, and i also work at one of canada's leading art suply stores. this is just awesome. i'm probably going to try this with some Tri-Art clear modeling paste, with a glossy finish. can't wait to see how it turns out.
thanks so much for the awesome tutorial!!
