loading
Step 4: Making It Happen
Now that you know how to work the main parts of the program, you should be able to figure out how to put the audio onto a cassette. But just incase you haven't figured it out, I'll tell you how to do that, and also how to get images off the cassette, or whatever you're getting images from.
  Once you've got an image made up in your template, and you're back on the TX tab, all you have to do is record the audio onto a tape. Press the red "TX" button to test your sound, and if you start hearing tones and weird computer sounds, then everything's working. Use a Male to Male audio cable to hook up the headphone jack on your computer to the microphone/input jack of your tape player, start the tape recording, press the red TX button again, and let it play through to the end. Once the sounds played through, everything is done, and now you have an image recorded on a cassette tape.
To read the image off the cassette, open the RX tab in MMSSTV. Then, use the same audio cable to plug the tapes headphone jack into your computers line-in jack. Go to the Options tab at the very top of the program, and click "Soundcard input level...". Make sure the Line-in input is turned all the way up, and then you're ready to go. Rewind the tape to just before the image, and press play.
If everything worked right, then an image should start slowly loading in the white space on the RX tab. This is the image you saved to the cassette. If the image has a weird tilt or shift, wait until it's done loading, go to the Sync tab, and right click the smiley face. Now go back to the RX tab, and the picture should be fixed.
I there a mobile app that does the same thing?
<p>great mam, really great</p>
Great but there is no computer available. Paul Allen actively eliminates start up microprocessors? It is strange that nobody , but nobody can build an actual computer. I am at the point where I know that a radix is a binary point similar to a decimal point in division. Flow charts for binary division can be drawn. There are homebuilt computers on youtube. These are limited to single individuals.
I've been playing around with MMSSTV for a bit, and I managed to work out that 'headphone output' mode on a netbook (if it is equipped with sound card management software provided by the sound card manufacturer) is not at all suitable for the transmission of images over audio. You should choose 'speaker output' mode if you are using this to send images via MMSSTV from a netbook's headphone port to a PC's mic input. PC speaker out &gt; netbook mic in works fine. Just watch out when it's the reverse... otherwise your picture will be severely distorted...
As a ham radio operator, I find this Instructable awesome. One of the first things I did when I got my general class license was to build an interface to hook my computer to my transceiver so I could send and receive SSTV images. <br><br>There are different ways of encoding the images. Some of the methods are better for long distance (DX) because the signal may take longer but the error correction makes for a better image on the other end.<br><br>I see no reason that a person couldn't transmit images like this across the telephone except for the limited frequency response of most telephones. But I've sent images across a room by doing nothing more than turning up the sound on the transmitting computer. <br><br>Maybe this will inspire folks to look into ham radio and how much it's changed with the advent of digital technology and help revitalize the hobby.<br><br>All in all, good job!
FYI: In the early 80's, there where several attempts to market &quot;video phones&quot; which used SSTV images. I recall there being two major drawbacks that forced marketers to throw the towel in. <br><br>1) It required identicle equip on both ends.<br>2) Not everyone wants to be seen when they answer the phone (Woman with messy hair, or answering in the bath room).<br><br>Talking while a picture was being sent, messed up the picture. I don't rememeber for sure but I think it took 10-15sec for each picture to be taken and sent.
This process isn't for live, real time transmission by any means. The &quot;SS&quot; in SSTV stands for &quot;Slow Scan&quot; and deservedly so. Ten to fifteen seconds is optimistic for transmission time. There is no voice transmission when sending a picture and, more from tradition than regulation, we switch to another frequency for voice (aka phone in the parlance of hams) communications.<br><br>The software isn't for image capture, either. Hams usually send pictures of their setups, maps showing their locations, cute/funny pictures and the like. There's one guy out of Oklahoma who likes to send pictures of Christian iconography. <br><br>I do remember the first attempts at &quot;video phones&quot; and they tried to send images using a cross between SSTV and analog signals. It was a pretty abysmal failure.
And 30 years later, smartphones are able to get high quality video-calling. Really, time flies by...
Another cool idea would be to use KipKays laser communicator (On YouTube: Weekend Project Laser Communicator) and use it to transfer pictures instead of just sound.
That exact same project popped into my head when I was thinking about what to do with the audio from this project. <br><br>If only I had a bunch of extra laser pointers.
If anyone does, I hope they make an instructable about it.<br>
I take that challenge.
Where is it?
I'm actually getting several lasers soon for another project, I may be able to try this soon.
Next step is to get an Amateur Radio License and do it with Radio like we do.
I recently have used SSTV to send images over a CB radio, and it comes through more clearly than a tape, as i was using my ipod to play it over Cb into my computer. Nice range
Would the picture be visible if the audio signal was ran through an spectrogram?
As long as the picture still reached the computer or a modem, you could still see the picture. Running it though a spectrogram shouldn't chance the pictures quality.
Awesome! Now I can be like my hero Aphex Twin and place an image into a song! Thanks!<br><br>http://www.youtube.com/watch?v=M9xMuPWAZW8
This isn't really all that amazing, because the commodore pets used cassettes too for storing infomation. Cool instructable though!
Great Instructable! Thanks. <br>Berith, yeah! Modems in computers do that every time you download something. When we all used to use manual dial-up modems and the baud rate was in the bps and kbps range you could hear the same computer type noises emanating from your computer during dial-up. That was your computer communicating via sounds with the internet service provider or BBS. <br> <br>If you want to communicate with someone on computers via phone lines, install a dial-up modem in each computer and play around with dialling one another and using the multitude of programs and games that support modem connections. It was great fun when online gaming was limited who you could connect to and who could get it to work :D <br> <br>Another common instance of image data transfer over phone lines is the common household and office Fax (facsimile). This is the whole kit and caboodle built into a box on your desk. It scans your page, dials your intended recipient and transmits the image in sounds. The other box picks up the phone, lists for the sounds, decodes the sounds, then prints a facsimile of the scanned page. Brilliant! :D <br>
Who is that tall man in the background?
In the last picture?<br><br>The man painting the building is Bask. It's a picture I took of him while he was painting a building near my house. The other picture is just a random computer to fill space.
This is a little similar to a thing I saw a couple weeks back about about sending secret messages images in audio files. check it out!<br><br>http://gizmodo.com/5807527/how-to-hide-secret-messages-and-codes-in-audio-files<br>
This is great!<br>Question: if you hook the exit from the cassette player to the input of the tv (where the antenna would go) would you see the image on your tv?
No. Connecting the audio from your recorder to your TV's Ant input will not work. The TV Ant is expecting a Radio Frequency (RF) Signal from the Antenna. That has been encoded with Digital or Analog Signals which then must be decoded by the TV set to be displayed for you to see.<br>Slow Scan TV (SSTV) only translates the sent picture, one picture at a time, to Audio, then receives the Audio and translates it back into a picture. It only does one frame without any voice or sound. <br>Unlike a television that receives and decodes audio and video up to 30 Frames in one second.
Ok thanks!<br>So, how did they use to see the SSTV images before the days of computers?
I think the earliest were actual special TV's that were low resolution and had slower phosphors to be able to display the signals directly without any sort of memory.
In reading what I wrote it may not be clear: Whether you turn on or off the beam depends on whether the image is light or dark at that point of the scan.<br><br>Great Questions!
skrbol is correct in the cense that initially the first SSTV was made using something called a Vidicon a &quot;memory&quot; screen of sorts. Later Ham operators used RADAR screens which were Cathode Ray devices with high persistence similar to today's television sets although the image stayed longer.<br>Powerfool: to transmit an image you only need a little information actually. It depends on the size, variation of color or gray scale. Unlike a computer that divides the screen in to little dots called pixels. Old tv's divided the TV into lines actually one line that started in the upper left corner of the screen and descended in a zigzag pattern toward the bottom. The second scan started in the top middle of the screen and interlaced or was place in between the first lines. Each screen or frame equaled 525 lines and, on tv's, the scan rate is 15,750 Hz. Imagine as the scan starts you turn on the beam or turn it off. That is what TV's and Slow Scan do Slow scan is just slower. TV's are more complex due to how the information is rec'd, and the resolution.
I've heard a few things about SSTV modems being used before they used computers. The modem could translate a picture to sound, and a sound back to a picture. <br><br>That's why there's so many different modes of SSTV. Most of the modem manufacturers decided to make their own modes instead of just use the ones that were already around.
Everyone has or thinks they have a more efficient way to compress the information. That lead to the different modes.<br><br>Great instructable! <br><br>It has brought up some great questions.... By the way modem stands for Modulate - Demodulate MOD - DEM drop one &quot;D&quot;<br>To transmit information you must somehow modulate then demodulate. So Modems have been around as long as transceivers.........<br><br>Keep up the good work.<br>- Phil
Brilliant! I love this instructable! I also tried to do this with an old Dictaphone, (the type that uses microcassettes). The result were recognisable, but severely distorted. This reminds me of something a spy would use...
Any thoughts about doing this on a microcontroller or FPGA/PLD to output to TV? I've been looking at the Propeller recently because if it's multitasking and apparent ease of dev, and it's video capabilities are often touted. Only issue I see is it's short on RAM (32k,) so you'd need external RAM for a frame buffer. There might be better suited chips, but it might be the quickest to get working, as video output (NTSC or 64 color RGB,) is pretty simple to implement.
Re: &quot;Because radio transmitters are expensive.&quot;, despite my username, I do pick up things and recently came across the cast-offs of a retiring HAM buff. There are boxes and boxes of IR components (devices (transmitters?) power supplies, transformers, caps, various other electronic items). Much of it is heavy. I am in San Antonio and would be happy to help get the stuff into the hands of someone who can use it. If a serious inquiry is made, I will list the box contents description.
You make me jealous. I'm always on the look out for things like that, but so far all I've found is an old ship's radio. I live a little too far from San Antonio, but I hope someone else can find some use for that.
This reminds me of dial-up Internet. It would be really cool to set up your own dial up or ADSL connection
I was thinking about writing an instructable on setting up a dial up connection actually. It's pretty easy, but I got kind of lazy when I tried writing about it.<br><br>If your computer runs windows, you can run a program called sexpots.exe, which forwards all incoming calls to a port on your computer. It's pretty fun to play around with.
i still use dial up on my brothers phone. <br>the phone is connected to an old lappy then the lappy uses it as a modem then i connect my school lappy to that then i set up wi-fi using my lappy the i conect my phone to the wi-fi so all of that goesbthrough a phone with usually 1 or 2 bars of gprs signal so it is really slow, but it works
That's really impressive! i'm quite young and never seen something like this before!<br><br>I have a question, do you know a way to do this same thing, but with raw data? like binaries or something like that? it would be really cool to pass &quot;encrypted&quot; data/programs to your friends so no one would figure out that your tape holds important information :D
Well I know it's possible, since most old computers used tape drives before floppy disks got cheap enough for normal people to use. But so far I've never figured out how to do it with newer computers.<br><br>It is possible to write text to cassette though, using the same method as in the instructable, but with a different program. The person who made MMSSTV also has another program called MMTTY, which is made for sending text over radio to other computers. After I wrote this I played around with MMTTY, and it works really well for reading/writing text from a cassette.<br><br>
great instructable but please fix the text in this step :)
there was a kid's video camera in the 80's that was based off of this principle, only the images were in b&amp;w, I think it was from Fisher Price if I remember correctly.
I love Ham radio! I've been a licensed operator since 2006 (I was 9 years old at the time).
fist of all, Michigan is perhaps the greatest place to live! and I recall an old toy video camera that used audio cassettes in-place of video cassettes that reminded me of this project somewhat. it was the fisher price PXL-2000 or pixelvision and was available in the 1960's
Could not be the 60's.
I had a PXL-2000 (I actually still have the manual with all of my old computer books, though the camera itself disappeared years ago). It was actually made in the late 80's (1987, according to Wikipedia).<br><br>I remember listening to a PXL-2000 tape on a standard cassette player. The recordings sounded a lot like those that would come from my Commodore 64's Datasette.
I've seen that toy camera a few times, and I remember being amazed that you could store video on a cassette tape. In a way this project was me making up for never being able to get my hands on one of those things. I'm glad I wasn't the only person who got reminded of that camera by this though.
Back in film school our lecturer told us about the PXL-2000, half the class were like &quot;You can shoot on audio cassette!?&quot;.<br>Apparently one of his favourite art directors shoots on this still.<br><br>Maybe there should be a part two: Making a PXL-2000.
This is the 1st instructable I've been compelled to do. Thank you.<br><br>I have the image on tape, but I can't get MMSSTV to hear it. I can't find a &quot;Select Source&quot; in the program. I'll try different combinations of Windows and Creative X-Fi settings. Win 7 has been an adventure I had not anticipated.<br><br>What is the spectral analysis that is occurring when the program 1st starts? It makes no sound and renders nothing.
About This Instructable
48,455views
232favorites
More by 0Ihavenousername0:Images On An Audio Cassette Computer Time Travel: Using a BBS Over the Phone
Add instructable to:
