Imitation Alka Seltzer for a fraction of the cost
As I was making bath bombs to give for Christmas I felt a little heartburn. I reached for the Alka Seltzer... Wow... $8.99 for 36 tablets! One dose is made of 2 tablets, so that comes to 50 cents per dose. Then I looked at the active ingredients. Citric acid and sodium bicarbonate. Exactly what I was using for the bath bombs! Sour salt and baking soda! I made a rapid calculation: one dose comes to 2 grams of citric acid, and 3.88 grams of baking soda. If I figure that citric acid costs $4/lb and baking soda is $1/lb, the exact same dose of alka selzer's active ingredients would cost me about 2.5 cents to make myself.... Twenty times less than the store bought version! OK to be fair, I didn't figure the cost of filler, and the store bought alka selzer also contained aspirin, but I neither needed nor wanted the aspirin. I was looking for heartburn relief only. Even if you end up spending more on the citric acid and less for the Alka Seltzer than I did, you'll still come out ahead.
Disclaimer: I am neither a doctor, a pharmacist nor a chemist. I figured out the dose of the ingredients by weighing them and then converting the measurements to volumes, because it's a more convenient way of measuring for most people. Also, since there is no aspirin in this mixture it will do nothing for headaches, hangovers, or flu-like symptoms. This is for acid indigestion, upset stomach and heartburn only. All the warnings on the Alka Selzer label apply for this concoction:
Warnings
Ask a doctor before use if you have a sodium-restricted diet
Ask a doctor or pharmacist before use if you are presently taking a prescription drug.
Antacids may interact with certain prescription drugs.
When using this product do not exceed recommended dosage
Stop use and ask a doctor if you have taken the maximum dose for 2 weeks
If pregnant or breast-feeding, ask a health professional before use.
Keep out of reach of children.
Directions
adults and children 12 years and older
Fully dissolve two teaspoons in 4 ounces of water before taking
2 teaspoons every 4 hours as needed, or as directed by a doctor
do not exceed 8 teaspoons in 24 hours
adults 60 years and over
do not exceed 4 teaspoons in 24 hours
children under 12 years
consult a doctor
Step 1Recipe
Recipe
I first tried to make tablets using the bath bomb principle: mix in a small amount to liquid (in this case I replaced the bath oils with agave syrup) and smush the mixture together. Perhaps with more patience the right balance could be achieved, but when the cute little balls started swelling, and ended up the next day as a bubbly, sticky mess, I opted for this dry, powdered version instead. Much less labor intensive to make, just as pleasant to consume.
Put the following ingredients into a bowl and mix thoroughly:
1/4 cup citric acid (aka sour salt or lemon salt)
1/2 cup minus 1 teaspoon baking soda
1/2 cup fructose
3 tablespoons cornstarch
Store in an airtight container. When needed, pour 2 teaspoons into a small glass of water, stir, and drink. Make sure your measuring spoon is dry and you don't get any water in your jar...
This recipe will yield about 66 doses. If you'd like to try it out with a single dose, mix these quantities into a small cup, then add water:
1/4 heaping teaspoon citric acid (aka sour salt or lemon salt)
1/2 teaspoon baking soda
1/2 teaspoon fructose
This makes a slightly smaller dose than the regular amount, but when it comes to medicine it's better to err on the conservative side.
90 comments
1-40 of 90next »
Apr 25, 2010. 11:17 PMTobita says:
I'm pretty sure you could compress it into a tablet if you were to mill the powder much finer before pressing it dry.
Feb 21, 2010. 4:01 PMlawdog323 says:
FYI- aspirin is great for your skin... :)
Dec 9, 2009. 9:13 PMlsrieck says:
 Really cool idea - but for me the active ingredient is aspirin.  I've ground up plain old aspirin, and added it to vitamin C, with some baking soda and come up with a pretty good substitute.  Good for colds, hangovers, upset tummies and the like.
Jun 23, 2009. 2:55 PMstephenniall says:
i made this and enptied out a old paracetamol Tablet thingy ! (could use a tablet organizer you know themt hings monday tuesday etc ) steralized it in my mini steamer (must make a ible on that too) and put this in them Made about 20 tablets because i left out cornstarch ! yay
Jun 24, 2009. 10:06 AMstephenniall says:
i didnt use the dose you supplied Plus i left some not in tablet form
Dec 19, 2008. 1:33 PMrattyrain says:
Do you think it would be possible to form a tablet by mixing the active ingredients with melted (liquid) sugar?
Jun 23, 2009. 2:03 PMomnibot says:
It seems some people are having problems with the stuff hardening if cornstarch is left out. Perhaps this can be used for making tablets?
Dec 21, 2008. 10:31 PMomnibot says:
I've been thinking about beeswax or gelatin to help form pills under pressure.
Jun 14, 2009. 9:49 PMalkatom says:
Made up a batch following recipe and 10 minutes later it hardened in the air tight container. One thing i left out was the cornstarch , didn't have any. Is it the cornstarch that keeps it from hardening?
Jun 16, 2009. 10:14 PMalkatom says:
Broke it up with a knife and hammer, added the cornstarch, and no more cement. Have been taking alkaseltzer for 40 or 50 years with the aspirin and this is a nice substitute. Thanks to the author.
May 16, 2009. 5:19 AMChicken+Bacon+Cheese says:
kid do u even know the cause of heart burn? it is excess acid in the stomach all u need to do is dissolve bicarb of soda in water and drink it
Apr 13, 2009. 4:54 PMJupitane says:
Very cool man!
Jan 2, 2009. 11:16 AMSoapyHollow says:
FYI, just plain ol bicarbonate (baking soda) is the traditional remedy for heartburn. You can stir about a teaspoon into water, and it'll settle tummy gas. :)
Jan 3, 2009. 9:21 AMSoapyHollow says:
Oh yeah, I wasn't criticizing. Just passing along folk wisdom. :) I'm sorry to hear that your bombs broke though. Lemme know if you want some help troubleshooting them. :)
Jan 3, 2009. 7:02 PMSoapyHollow says:
Cocoa butter is really tricky in bath bombs. Any butter is. I recommend saving the butters for making melts instead. (I should do an instructable on my chocolate raspberry cocoa and shea bath melts. They're beyond decadent, and super easy to make. ) To get a good chocolate color, replace a tablespoon or two of the corn starch with cocoa powder. (The unsweetened stuff...you don't want to attract ants.) I'd stick to using a light oil and water emulsion for the liquid. To add milk, replace up to an 1.5 oz of corn starch with milk powder. Again, try to find one that does not have corn syrup solids in it. Cheers, and happy bathing!
Jan 3, 2009. 8:44 PMSoapyHollow says:
Keep your butter in the fridge, and it's good practically forever. You can freeze it too, but I find that it makes the butters "grainy" for lack of a better word. You can also add up to 2% tocepherol (liquid Vit E), and that will add a natural preservative. But seriously, in the fridge...universes will end before that stuff will go rancid. :)
Dec 26, 2008. 12:16 PMharaldbreisgauer says:
I am neither a doctor, a pharmacist but a chemist. I think I should say some warning words. I think this is not a recipe for alka selzer but for a soft drink. The aspirin (acetylated salicylic acid) is used as pain reliever and as a antipyretic medicine and against every kind of inflammation. Citric acid and sodiumbicarbonate are only inside for galenic purposes. You can add lemon juice to carbonated water, too but that will not result in a proven medicine. Instead you can use a tea of willow bark or blackcurrent juice, there is a little portion of saliicylic acid inside but salicylic acid is more agressive to your stomach than the acetylated compound. My advise is to use this recipe for fun or because you like its taste, and to use Aspirin tabletts when you are ill. Aspirin is the working agent, and nothing else. Carbonates and acid form nice bubbling solutions (t.rohner already said that), and carbonates were used for treatment of pyrosis (heartburn) . But when using them for this purpose they produce a big amount of gas in your stomach and that is not really healthy. Nowadays pharmacists don't recommend carbonates as a medicine for treatment of pyrosis. Having said that all theres only one thing to mention: Cheers!
Dec 27, 2008. 6:07 PMharaldbreisgauer says:
I admit that I didn't knew this kind of alka seltzer. I know alka seltzer, like aspirin as a synonym for a preparation containing acetylsalicylic acid. In your instruction you mention that "the store bought alka selzer also contained aspirin". The use of citrate buffer as a medicamentation against heartburn was not known to me before an I think it is not very common here. Different markets different products. Mea culpa. I think you should make clear in your instructable that its an "imitation" of alka seltzer heartburn relief and not the classic one. By the way the recipe citric acid with baking soda water and sugar is the classical recipe for effervescent powder. I think it can't be in your purpose that people with headaches, fever influenza etc. use effervescent lemonade instead of a proven medicine. I hope you don't see my comments as offense but as a proposal. Happy new year and Cheers!
Dec 24, 2008. 3:10 PMflybynightenterprises says:
I like Alkaseltzer and its generics for the taste, which is probably largely due to the aspirin. It is kind of like a Fizzie for grownups. How's the taste of the aspirinless version?
Dec 23, 2008. 6:21 AMClayOgre says:
Hmmm...this has me wondering. When I was a kid, there were these sort of "beverage mix" things you could buy, called "Fizzies". You dropped them into a glass of water and they made flavored soda water. Haven't seen them for sale in years. Wonder if you couldn't use this method to make them, but I have no idea how, since the end result would have to taste considerably different than alka seltzer, and have a totally different end purpose.
Dec 23, 2008. 6:22 AMClayOgre says:
Ha! They still make 'em.
http://www.fizzies.com/
Dec 23, 2008. 5:52 AMpastorkev says:
"He who pays unnecessarily for overpriced medications and overpriced diagnosis is a fool for a patient."
Dec 15, 2008. 5:02 PMomnibot says:
Cool .. my partner has a bad stomach and we just go for the bicarbonate. I'll try this as well. Before she used a fortune in anti-acids. My personal view is that having a sour stomach on a regular basis is a symptom of a real problem and anti-acids are just a temporary quick-fix, change your diet and see a doctor. Good instructable, this will save a lot of money for a lot of people. You wouldn't happen to know what Efexor antidepressants are made of by any chance? ;)
Dec 15, 2008. 9:47 PMPapersatan says:
I started getting heartburn at 22, it gradually worsened for a year until I was taking antacids 6 times a day and sleeping sitting up. Turns out it was a symptom of something else; I had an undiagnosed food allergy. I think people reach for the antacids because they assume it is caused by things they are choosing not to change. I know I didn't go to a doctor because I assumed they would tell me to lose weight and eat better and take antacids. Which, judging by my experience getting my allergy diagnosed, is what would have happened, but that doesn't change the fact that it was a symptom and I should have treated it as such.
Dec 16, 2008. 9:03 AMomnibot says:
Interesting. My partner is 22 yo and your description could fit her. We've figured out she has problems with milk, soy and eggs but not gluten by excluding them from her diet. What was your allergy?
Dec 16, 2008. 9:14 AMPapersatan says:
Sulfites, which translates to anything made with wine, dried fruit or processed corn, including corn syrup and corn starch. Because it is not one of the 'big 8' no one ever brought it up as a possibility, but I was told to go on a rotating diet, basically eat the simplest foods possible and only eat the same ingredient once every 5 days. That helped me figure out a pattern of my reactions (after the year of heartburn I started breaking out in hives) and from that which things I was allergic to.
1-40 of 90next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
237
Author:belsey
I am trying to work on an overly ambitious tome, MAKE ANYTHING, a handbook for saving money, living green and having fun with trash. Trouble is, I keep getting distracted by pop-ups -- the cards, not ...
more »
