Disclaimer: I am neither a doctor, a pharmacist nor a chemist. I figured out the dose of the ingredients by weighing them and then converting the measurements to volumes, because it's a more convenient way of measuring for most people. Also, since there is no aspirin in this mixture it will do nothing for headaches, hangovers, or flu-like symptoms. This is for acid indigestion, upset stomach and heartburn only. All the warnings on the Alka Selzer label apply for this concoction:
Warnings
Ask a doctor before use if you have a sodium-restricted diet
Ask a doctor or pharmacist before use if you are presently taking a prescription drug.
Antacids may interact with certain prescription drugs.
When using this product do not exceed recommended dosage
Stop use and ask a doctor if you have taken the maximum dose for 2 weeks
If pregnant or breast-feeding, ask a health professional before use.
Keep out of reach of children.
Directions
adults and children 12 years and older
Fully dissolve two teaspoons in 4 ounces of water before taking
2 teaspoons every 4 hours as needed, or as directed by a doctor
do not exceed 8 teaspoons in 24 hours
adults 60 years and over
do not exceed 4 teaspoons in 24 hours
children under 12 years
consult a doctor
Remove these ads by
Signing UpStep 1Recipe
Put the following ingredients into a bowl and mix thoroughly:
1/4 cup citric acid (aka sour salt or lemon salt)
1/2 cup minus 1 teaspoon baking soda
1/2 cup fructose
3 tablespoons cornstarch
Store in an airtight container. When needed, pour 2 teaspoons into a small glass of water, stir, and drink. Make sure your measuring spoon is dry and you don't get any water in your jar...
This recipe will yield about 66 doses. If you'd like to try it out with a single dose, mix these quantities into a small cup, then add water:
1/4 heaping teaspoon citric acid (aka sour salt or lemon salt)
1/2 teaspoon baking soda
1/2 teaspoon fructose
This makes a slightly smaller dose than the regular amount, but when it comes to medicine it's better to err on the conservative side.
http://www.fizzies.com/
