Improve a Simple Didgeridoo
3,731
19
6
Posted
Introduction: Improve a Simple Didgeridoo
That's how the didge looked like when I bought it. I bought it from a person in private, she had brought it some 20 years ago from a trip to Australia, played it a bit and than forgot it. It's a simple, yet good didgeridoo, probably from Eukalyptus wood. It was rough cut at the bellend with plenty of excess material at it, and layered with a simple light brown varnish. The sound was OK but due to the small bellend a little low in volume.
Step 1: Removing the Varnish
First, I borrowed a tool from a neighbor who's a carpenter. With this tool carpenters usually remove the bark from branches etc. It was perfect for removing the varnish.
You can do this step as well with a sharp and reasonable big knife, it will just take a little longer.
Step 2: Sanding the Didge
After removing the varnish I sanded the didge. I have an electric tool for such work, but you could sand the wood by hand as well. In either case start with a rough sanding paper with a grain of approx. 120, then use finer grains. My finest was 400, but you could go further.
Step 3: Widen the Bellend
In this particulary case the bellend had a lot of excess material. I used a long chisel and a wooden hammer to remove the material. This is the most complicated and dangerous step. Be careful not to remove too much wood, or you're instrument will have a wall too thin or even a crack. Thus work in little steps, removing small chunks of woold subsequently. In the first foto you see the bellend before being worked on, and in the second foto you see the same bellend after all works on the didge are finished.
Step 4: Chisel and Hammer I Used for the Bellend.
Position the chisel at a piece of wood you'd like to remove. Hold the chisel in quite a flat angle. If you hold it too steep you will remove too much wood, and either the instrument's wall becomes too thin or even cracks immediately. Use the carpenter's wooden hammer on the chisel, but work soft and cautiously.
Step 5: Hanging and Oiling
After sanding you have a number of options to finish the wood. You can either use varnish, wax, or a variety of oil products. I decided to use boiled linseed oil for the outside (I will use the same for the inside next week).
The easiest way to apply the linseed oil onto the didge is by having the didge hanging. For this purpose I made a simple application from a random piece of timber of the right size, an old bicyle tube, a random screw, and a rather large washer. The bicyle tube is put through the didge and its end tied to something high at a wall or at the ceiling. The piece of wood holds the didge (it's like the didge is balancing on the wood). Make sure that both tube and piece of wood are strong, and the washer is large enough to securly seperate tube and screw. In my first experience I didn't use a washer at all and the screw slipped through its hole through the tube, and the didge fell to the ground. Not nice.
So, once your didge is hanging securely, you can use a paintbrush and layer the wood with the boiled linseed oil. Read the instructions on the linseed oil package, they will tell you exactly how long you have to wait until you can add a second layer, and probably a third. The didge will probably suck a lot of the oil since it's raw wood now.
And you should have your floor covered with a really thick layer of old newspaper or something alike.
Step 6: Let It Dry
After soaking the wood with a couple layers of boild linweed oil your didge needs a couple of days to dry. The interesting aspect of the oil is that it will really harden the surface and make it water repellent. Check once again the description of the oil's package, it will tell you more about the product's drying time.
At the end take a piece of soft fabric and remove the oil remains.
Step 7: Optional: Construct a Mouthpiece
With most simple didgeridoos it is useful to construct a mouthpiece to make playing easier and more comfortable. I opted for pure and real beewax, but the material has it pros and cons. You'll find a lot of information online if you search for didgeridoo mouthpiece.
Step 8: Result: Enjoy Your Didge
Here's how the didge looks after the whole process. I like it much better that way than befor. Even more important is of course that the sound is improved too due to the widened bellend.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
7 Comments
needed to know that thanks for the info
Hi @tress2323 Are you going to build a didge or to improve one you alread got? Wish you success and fun.
Aboriginal elders say this instrument is for MEN ONLY! Women get killed for playing didgeridoo!
Yeah, you hear that a lot but it's not true in that plain way. First of all, what we white people call a didgeridoo (and I will stick to this name) is called quite a number of different names among the many aboriginal tribes. Secondly those didgeridoos are used for a wide range of different activities, and most of them just fall into the domain of entertainment. The use of didgeridoos in sacred spiritual context is relatively rare and even then, tribes have different rules on how the didgeridoo has to be played and who might play it. In certain rituals of certain tribes only men play the instrument. I think it makes completely sense if, for example, only boys and men participate in a ritual for boys to become men.
Considering the large diversity of first nations in Australia and their commons it is rather rude of white people to ignore the differences. As white people it is our responsibility to respect cultural diversity and customs, and to stop spreading simplifying rumor. BTW, it is also often said that this instrument is several tenthousend years old, but recent science has proof, that the didgeridoo was neither wide spread across Australia, and just a couple thousand years old when white colonisation started.
Wow, these upgrades look excellent. Your didge looks great and will hopefully last for decades to come! :)
Hey seamster, thank you for your nice comment. Since this is my first instructable I entered it into the contest for first time authors. It would be great if you'd like to vote for my instructable and also forward it to others.
