Here is an idea of how to do it that might spark your imagination.
3 Simple Ways to
Share What You Make
Other ways to share:
Using an art of illusion scene file to make, test and compare a funnel cooker with othe…
by
gaiatechnician
"Compound" parabolic solar cooker, make a template with technical drawing
by
gaiatechnician
Alternative to Scheffler solar kitchens
by
gaiatechnician
Solar design t-square for designing solar cooker reflectors
by
gaiatechnician
Kyoto trough solar cooker mimics a parabolic dish without a thousand cuts!
by
gaiatechnician
Solar parabolic cooker with the mechanical mathematician!
by
gaiatechnician
Optics experiments on the cheap
by
gaiatechnician
Adapt a clock today! Cheap trackers boost solar panel and solar cooker performance.
by
gaiatechnician
Making and using a "compound" parabolic solar cooker (Large project)
by
gaiatechnician
Comments: 19
Rating: 3.99
© 2012 Instructables
All Steps Viewing
and a couple of new videos about equatorial mount (one is on instructables)
Brian
Like mentioned below the sun tracker robot looks like it would do a pretty good job of this.
http://www.instructables.com/id/Robotic-Solar-Powered-Sunflower/
Although I am not an electronics expert., I maybe someone could help us out here, but I do have some thoughts on this.
You could utilize one sunflower robot with a vertical orientation. A potentiometer could be mounted to this robot and tied in to a whetstone bridge. Another leg of the whetstone bridge could then be tied to a potentiometer/float in your water.
My thoughts are this: As the robot rotates, it changes the potentiometer resistance which inturn changes the control voltage across the whetstone bridge. The potentiometer float is either adjusted up or down with the addition or subtraction of water from the tub until the voltage is equalized between on the whetstone bridge.
A small PLC or some sort of control circuit be utilized to monitor the voltage change on the whetstone bridge. The control circuit could then operate either two solenoid or proportional valves. One of the valves would let water into the tub and one would release it from the tub.
One problem that may occur is that the waves in the tank/tub would create an inconsistent signal and so the water near the float would need to be protected/isolated from this wave action. The water that is coming into or exciting the tub could be mounted below the expected waterline and at the opposite end of the location of the float. This would help to eliminate the motion of the water. A cover over the water would help to eliminate the influence of the wind or bugs dropping into the water.
I suppose that this potentiometer idea could be tied to your clock or better yet the a PLC's internal clock could control the water level directly with the feed back from the float.
If your interested you can find some inexpensive PLC controls at: http://www.aboutplcs.com/directlogic/ You may be able to set up a PID control system and thermocouple temperature sensors on this if you want to go over the top with this.
http://solarcooking.wikia.com/wiki/Tracking
And I had nothing to do with it.
with little effort, it can be adapted to use it in 2 axis.
It's really cheap, and a local boy scout group made a similar project of a solar tracking oven.
The trick is to put photodiodes near, with a black thing between (sorry for my brutal english...), so one will be less exposed to sun then the other, and the system balances itself so they're always facing the sun.
Questions? :)
