This is very useful when you are beginner in electronics technology.
I'm going to make an 12V adjustable voltage.You can adjust the output voltage by the potentiometer.
Minimum of 0.01mV.
Maximum of around 12V.
You will need:
*1 pc transformer 12V output with a current ranging from 100mA-2A
*8 pcs 1N4001 diodes
*2 pcs 1000uf capacitors,rated with 25V
*4 pcs 100nf capacitors,you can also used 0.1uf capacitors,rated with 16V
*2 pcs 1uf capacitors,rated with 16V
*2 pcs 470 ohm resistors,1/4 watt
*2 pcs LM7812 regulator or AN7812(the same output voltage with the LM7812)
*2 pcs LED 5mm(3V)any color you want
*2 pcs 50k potentiometer
*1 pc rocker switch
*File Case
*fuse(1A)
*Fuse cartridge
*hook up wires or jumper wires
*Illustration board to make base of your project
*Breadboard
*Printed Circuit Board
All these materials needed are available in electronics store or you can see in a radios,amplifier,etc....
Remove these ads by
Signing UpStep 1
Put the transformer inside the case.
Tap the fuse and switch to the transformer.
I think it will work as tested
If you want to control the voltage output then use a variable voltage regulator as the LM317 (quite common 1.5A if cooled correctly), using the pot in the ADJ pin. For more current you need K serie (LM317K), other different regulators, specific design to supply the extra current -check datasheets- or design a regulator circuit.
Furthermore the efficiency of the power supply drops using the pot in the output stage because most of the power is dissipated as heat (the psu alwys supply +12V regardless you need 1V for example, so this excess is disspated).
Resuming: that potentiometer is not well placed and could burn if you need max current at low voltage. If a shortcircuit happens you could fry your circuit because it will receive full +12V.
First,make an voltage rectifier with the use of 1N4001 diodes.
Connect the rectifier to the transformer,after that connect the other side of the rectifier to LM7812 regulator before attaching the capacitors to the regulator.
Lastly connect the potentiometer.Attach the 470ohm resistor with the LED to the center side of potentiometer,the center side of potentiometer will serve as final output of 12V supply.Connect #2 of the regulator to the left side of potentiometer,and connect the right side of potentiometer to the negative output of rectifier.also attach the negative terminals of all capacitors to the negative output of rectifier.
The 100nf cap does not have polarity,so you can interchange when installing.
