There are already a few instructables about using linear voltage regulator chips to power low-voltage experiments and projects. This is my variation on those, using a low dropout regulator to allow lower input voltages and a coarse/fine adjustment system.
Remove these ads by
Signing UpStep 1Parts and Tools
LDO voltage regulator such as MC33269
TO-220 heat sink and mounting screw
Capacitors to filter the regulator's input and output circuits
240 ohm resistor
Two potentiometers: 1Kohm or more for coarse adjustment, 100 ohm for fine
I used trimmers for both pots, since they're compact and hard to accidentally adjust
Power connectors: a PCB-mount coaxial jack for input and screw terminals for output are usually the easiest to work with
3-4 square inches of perfboard
Some hookup or bus wire
You should have these tools available:
Soldering iron
Small screwdriver
Pliers and wire cutters
A sharp knife that can carve your perfboard such as a regular #11 X-ACTO blade. (or a 1/8" drill bit)
Harder to design (I haven't had a chance to build one that works very well yet) but more flexible and more efficient.
If yes, how should I plug it to the circuit?
There are a lot of other regulator parts that work the same way that you could use instead, such as the LM1117
