Step 1Make the PVC vest with polystyrene insulation
(i too also advise you to consult from his picture because they are very useful)
Here are some convenient parts descriptions:
Rib cage (all pvc parts are in 3/4 inch)
1 3/4 inch pvc pipe
7 1.75 inch "ingots" (parts you need to put in between parts)
11 45 degree pieces
2 90 degree pieces
3 "T" pieces
1 "cross" piece (has fittings for 4 tubes)
2 "bended pieces" (can be obtained in your electrical department. should be
grayish looking)
1 1 inch polystyrene plumbing insulation (optional, but just for looks and
comfort)
1 cover cap (it should screw in without an ingot)
1 premixed pvc cement
estimate: ~20 dollars
(if that seems too much, it is useful if you want to attach it to your boom mic, which usually requires lifting your arms for a long time. but if you simply attach it to the rib cage, no pain, no game! But more on that later....)
As the guy that i got it from, here are my following tips:
1. Pre-fit all your parts before gluing
2. make sure you are gluin the right part to the part is was originally connected to (or else the scale of it gets all ugly and tends not to fit well)
The finished product should be the picture above. Notice that i added the insulation and didn't buy or add the "bogen swivel" because i felt 30 dollars was too much anyways. anyhow, i solved that problem later on as we build the swivel attachment.
Add Comment
