I'm just mad about turquoise, turquoise is mad about me..
Pauric suggested I end my negative hatred of Valentines Day and join this competition instead :-)
So here it is, a little necklace made out of all sorts of precious bits and pieces, with a few tools and some easily learnt skills.
Step 1: Materials
you will need:
50cm of chain
1 large jumpring
several small jumprings
several headpins (the long bits of wire with bobbles on)
lots of special buttons and beads found all over the place
optional:
you know those little sample sheets you get with processed photos? Well, cut out a favourite photo, and cover it in some kind of gloss to make it stronger. The instructions for adding eyelets are at the end.
Step 2: Tools
you only really need a pair of roundnose pliers and some cutters. I use strong scissors, but you're better off with wire cutters.
The hammer and eyelet puncher are for the little photo if you decide to use one.
Step 3: The chain
open up the large jumpring and attach it to the end of your chain, then close it again.
Step 4: The chain contd
thread the chain through the jumpring to form a loop at the end of the chain.
Step 5: Putting beads onto the headpins
thread a bead on to the headpin. Using the roundnose pliers, curve the wire round.
Step 6: Putting beads onto the headpins 2
cut the wire where it meets the bead again.
Step 7: Putting beads onto the headpins 3
curve the wire around a little more with the pliers so it forms a closed loop.
Step 8: Putting buttons etc onto headpins
using some of the excess wire which has been been cut off a headpin, use a pair of pliers to form a complete loop.
Step 9: Putting buttons etc onto headpins 2
thread the button on and curve the wire around it, as in the picture.
Step 10: Putting buttons etc onto headpins 3
turn the wire around itself as shown, and cut off any excess.
I really like this style. Beautiful work.
ting-a-ling7 years ago
Beautiful necklace! I make jewelry from all kinds of things and I'll have to try this. Really cool way to put it on too.
annanomsa (author)  ting-a-ling7 years ago
thanks ting-a-ling, glad that you like it!
is that a guitar pick on the necklace?
hi there! No it isn't, its a button, but i did recently see a fantastic example of a necklace made with guitar picks, it was rather fabulous!
HamO8 years ago
Very well done instructable. great close ups. Beautiful neck uhh necklace.
jtobako8 years ago
any hints on how to keep the eyelet from collapsing like mine always do?
annanomsa (author)  jtobako8 years ago
hi jtobako, good to hear from you. hmm, good question. I tend to try and push the eyelet through the paper with my fingers before I hammer it down. That also means you can get it in exactly the right place. But other than that I can't think of anything. Let me know if this helps. Cheers, AnnaNomsa
