This tank was made with parts that where on hand a many many years ago. I had to take it apart because of a small leak and wanted to show how it was made.
Precautions
Use an EMPTY propane tank. You don't want gas leaking out and causing an explosion. Also compressed air can be dangerous. I'm not sure what a propane tank is rated for but keeping the PSI at a reasonable amount should be OK.
Remove these ads by
Signing UpStep 1Whats needed
- standard EMPTY BBQ propane tank with vale removed. Preferably newer then the one I used
- Air gauge 0-100 PSI (could go higher then 100)
- 1/4 female T
- 1/4 T male/female though female take off
- 1/4 male nipple
- 3/4 to 1/2 reducer
- 1/2 to 1/4 reducer
- 2 female air couplings
- pipe joint compound
- 5/8 wrench
- 11/16 wrecnh
- 3/4 wrench
- 3/8 to 1-1/4 adjustable wrench (1" wrench)
My idea is to add them inline using 3/4" Schedule M copper pipe. I'm not interested in quick removal; these are intended to stay in place. I plan to mount them upside down off the main copper line so they become self draining. If I set up the line in my garage / workshop horizontally along one of the roof trusses, the pipe can support the tanks in line. I'm planning to use 3/4" threaded adapters to tees inline and add a dropped water trap similar to a raised air hammer chamber in home plumbing, but with a ball valve at the end to pull off the accumulated water. Tees along the line can provide access for tools and so forth. Any thoughts?
