InchWorm Robot
Introduction: InchWorm Robot
This instructable was created in fulfillment of the project requirement of the Makecourse at the University of South Florida (
This is an Instructable on building an inchworm robot. This particular model was build for Make Course at the University of South Florida. The robot is designed to take small precise steps in a straight direction.
Step 1: Robot Body
First step in building a robot is designing its body. All the parts were designed in Autodesk Inventor and 3D printed. Only 2 parts had to be purchased.
Picture 1: Black Box, provided with the MakeCourse kit
Picture 2: Rear leg, 3D printed. The slit on top allows the leg move up and down in order to keep the body straight.
Picture 3: Front leg, 3D printed. Fully attached to the black box.
Picture 4: Rotator, 3D printed. Features an opening for the servo head to be inserted. This is the rotating part.
Picture 5: Rod, 3D printed. Is attached to the rotator and the rear leg. Delivers the motion to the rear leg.
Picture 6: Wheel, 3D printed. The opening in the middle is for the bearing to be inserted in.
Picture 7: Axle connector, 3D printed. Connect to the steel rod axle, and fits into the bearing to hold wheels.
Step 2: Purchasing Parts
Only 2 parts were purchased: steel rod for the axle, and one way ratchet bearings for the wheels.
The bearing have to rotating in one direction-forward. Therefore, when placing the bearings, make sure they are rotating the right way.
Links for purchase:
Steel Rod
Step 3: Body Assembly
After all the parts are obtained, assemble the body. Attach the front leg to the box first, then attach the rear leg. Put the axle rods through the openings in the legs, and attach the wheel assembly to the axle. Make sure wheels rotate in the forward direction.
Further, attach the rod to the rear leg, and to the rotator. Attach the servo motor inside the box and attach the rotator to the servo.
Make sure all parts fit nicely, without moving around.
Step 4: Control System Block Diagram
Create a control system block diagram to see how the control of the robot are gonna be done. This robot features proximity sensor, that runs the servo, if an object is placed closer than 10 cm to the proximity sensor. It also uses LED lights to indicate whether or not the robot is moving or standing.
Step 5: Circuit Board
The circuit board was then built. The image shows the completed board, as well as a Fritzing diagram. On the diagram, a infrared proximity sensor is shown, but ultrasound sensor was used for the actual robot.
Step 6: Arduino Sketch
Provided here is the complete Arduino sketch used for the project. After assembling the robot together and uploading the sketch, the robot will move forward when an object is placed within 10 cm of the proximity sensor.
PURPOSE: Inchworm Robot Created by
Mikhail Ivanovsit DATE: 4/13/2016 *******************************************/
#define echoPin 6 // This is the echo pin
#define triggerPin 7 // This is the trigger pin
#include //include proximity sensor library #include //include servo library
Servo myservo;
int pos=0; //define a variable to track the position of the servo
void setup() {
Serial.begin(115200); //start serial communication
pinMode(echoPin, INPUT);//set pinmodes
pinMode(triggerPin, OUTPUT);
myservo.attach(13); // attaches the servo on pin 9 to the servo object
myservo.write(pos); // sets the initial position of the servo to 0
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
digitalWrite(3, HIGH); //set the red LED to be on, and the green LED off
digitalWrite(2, LOW); }
/***************************main loop*********************************************************/
float check; //variable to track the distane
void loop() {
Serial.print("The distance is : "); //start serial monitor to track analyze the code
digitalWrite(triggerPin, HIGH); // make a 10usec pulse, use the proximity sensor
digitalWrite(triggerPin, LOW); //turn off the trigger pin
float distance = pulseIn(echoPin,HIGH); //now read the pulse that is sent back by the sensor //pulseIn returns the pulse length in usec
distance= distance/58; //the distance in [cm] is calculated by pulselength[usec]/58
Serial.print(distance,DEC);// send the measurement to the serial monitor
Serial.println(" cm"); //serial monitor is used to keeo track of the data obtained by the proximity sensor
check=11; //assign an initial value to check higher than 10 cm
myservo.write(0); //return servo to position 0 in the beginning of the loop
delay(500); //delay was set to allow the servo to complete the 180 degree motion
check=distance; //assign variable check the value of distance
if (check<10) {
myservo.write(80); //if the distance is less than 10 cm, move the servo to position 180
digitalWrite(3, LOW); //light up green LED, and turn off red LED
digitalWrite(2,HIGH); }
else {
digitalWrite(2, LOW); //if the distance is more than 10cm, then keep the LEDs in initial state digitalWrite(3,HIGH);
    • Epilog Challenge 9
      Epilog Challenge 9
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    Cool! I would love to see a video of it inching along! :)
