3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Increase effective distance on 'ebay' flash remote trigger transmitter with antenna
Increase effective distance on \
Camera buffs can purchase inexpensive versions of remote triggers for external flash units, controlling either hot-shoe or 'studio' type flash units. These triggers suffer from low transmitter power and thus small effective control distance.
This mod adds a correctly sized antenna, effectively increasing applied power and thus allowing operation from much greater distances. I have seen increases of tenfold in control distances after this mod.
This mod will show how to open the transmitter (RF-04/RF604), create the antenna wire, locate the place to attach the antenna, mod the case, and the final construction. Enjoy.
Note: this instructable was derived from material presented in the Strobist blog, here, with the actual article here. The original description is here.
I found this model on ebay, from a great supplier: Magic_Trigger. There are others on ebay and other locations, but I can't speak to the exact design they use or how to modify them, but similar techniques can be used.
Step 1Open the Transmitter
This works for the RF-04 and RF-604 transmitter types.
Start by opening the transmitter body: remove the single screw at the front of the bottom of the case. It's a phillips head and small. Once this screw is removed, pull the top off at the front. Don't worry about loose pieces, because there aren't any (except for the top and the screw).
20 comments
Jan 7, 2012. 9:37 AMBytesmiths says:
The antenna length is not so simply determined as implied here.
In fact, the impedance presented to the RF amplifier will be extremely different for odd number of quarter-waves (low impedance, about 30 ohms) as it will be for even number of quarter waves (high impedance, several thousand ohms). The optimal reception pattern will be different, too, tending toward broadside of the wire direction for odd quarter wavelengths to the end of the wire for even quarter wavelengths.
So the best thing to do is to make it an odd number of quarter wavelengths for maximum power transfer and for optimal reception pattern.
This article in fact recommends a single quarter wavelength -- which is great! But don't fall into the trap of thinking "longer is better" by trying a 1/2 wavelength or even a full wavelength.
Jan 7, 2012. 9:30 AMBytesmiths says:
For optimum range, you should leave the antenna straight.
Coiling it like this creates an inductor that effectively makes the antenna longer than its physical length. It may only be nanohenrys, but at these frequencies, a little inductance goes a long way.
Nov 3, 2011. 4:22 AMjoudas says:
great instructable, mine has little longer antena on pcb (13cm) but it was not enough, I cut it and use 17,3cm wire.
Results:
before: reciever with fresh batteries max 7m, reciever with old batteries max 4m
after: 10++m both of them
Mar 28, 2007. 1:48 AMSacha says:
Strange. I did this mod yesterday and afterwards the range was decreased to only some millimeters. After I removed the wire-antenna the range was original again. Of course I cut the length of the antenna as suggested here. I suspect the heat shrink tube could shield the electromagnetic waves. I'll try it tomorrow again but without the heat shrink stuff.
Oct 11, 2010. 5:10 AMdave950 says:
I ran into the same problem when I done the mod, but I found a fix. Like yourself I used a thin multi-strand wire that was 75mm long. After trying it on both holes I could only get 100mm of range. So I tried a solid copper wire about 260mm long, that I got from a coaxial cable. I stripped it bear and soldiered it on. It worked! I went from from getting 10m of range to 30m of reliable range and up to 50m of range but it is inconsistent. I thought I would then cut the cable down to 75mm to match the wave length and back came the problem. So I got a new wire about 270mm long and it's working again. I have since wrapped the wire in a electrical shirk and haven't had a problem. I can only put it down to an earthing or resistance problem. I have checked it with a multi-meter and can't find anything.
So once again. If you find your range has been drastically reduced by the mod. Use a sold wire like from coaxial cable and make it at least 260mm (10.2 inch) long.
NOTE: I have also done a AA battery mod to the receivers.
Mar 30, 2007. 3:23 AMSacha says:
Still no luck. I started with a wire length of approx. 7" and tried to fire via the test button. After each unsuccessfull test I cut approx. 1mm off and tried again. Most of the time it didn't even work for distances of one inch. There were some lengths (shorter tha 5") which worked for some meters but I never got a longer distance than with the on circuit antenna. Stopped when the antenna got as short as approx. 2"... After I desoldered the wire it worked again. Funnily enough I have to wait a second or two after a test shot before trying again or it won't work even with the original antenna. This was even before I altered something at all. Battery voltages ar 12,2 and 3,1V which should be fine. I have no clue at all anymore although I once learned electronic technician. Even with the worst antenna/wavelength match it should work for some inches I suppose.
Mar 10, 2008. 8:14 AMpskarsjo says:
I had the same experience. Completely dead after adding the wire as described. However, I kept cutting off 5mm pieces until I had a small stub of about 2.5" when I managed to trigger at a foot or two. Further cutting gave me a range of about 50 yards (5 times what I had before) with a wire length of about 2". So don't give up! Keep shaving off bits of wire.
Jul 9, 2007. 4:15 PMBlackx says:
Thank you for the instructions. I proceeded as described and my range seems to be improved significantly (I will try to do the better measures later).
However, I had to do one change: I had to use the second hole in the other front corner of the PCB. If I connected the antenna to the hole pictured in th Step 2, not only that the signal won't get to the receiver, but also the red light ON THE TRANSMITTER almost stopped flashing.
I don't know if it was some short circuit or something (I am not into electro thingies), but it worked after touching the second hole. I should note that this was not my idea - I have read somewhere else (on Flickr?) about someone who used another hole too.
Jul 10, 2007. 4:30 PMBlackx says:
Strangely enough, today's tests showed that: 1) it didn't matter which of the two holes in the PCB is used 2) the range was extended to about 20 meters from the original 5 - 8 3) the exact antenna length didn't make the difference... 14,1 cm or 15 cm or something around 40 - 45 cm... the results were the same (the long antenna had to be in the U shape though (don't know why)) 4) The no-fires of the flashes are gone. 5) Receivers work even close together, which was very unreliable before the modification. Anyway, I am satisfied even though some people managed to obtain much greater ranges.
Apr 21, 2007. 3:32 AMNT says:
I just tried it and had basically the same results as Sacha, although I did not test quite as thoroughly. The only thing that seemed to work was a full-wavelength antenna hanging straight - after twisting it into a more manageable form it no longer seemed to help at all. An 1/4 wavelength or thereabouts antenna effectively reduced the working distance to a couple of centimeters. I'm wondering what could explain this major difference in results... Mine is a 433MHz unit as well and has the same FS-616 board. How close should the antenna length really be to 1/4 for this to actually work? Are we talking millimeters or centimeters of tolerance here?
Apr 15, 2007. 5:38 PMgoffen says:
Btw has anyone seen a solution to make the recever/trigger set off flashes that won't work ? (I have two cullmann 42's and one Pentax af360fgz that refuses to go off). Goffen
Apr 15, 2007. 5:33 PMgoffen says:
I can offer a much simpler solution. Especially for thoose not comfortable with a soldering iron. Find any cable with a 3.5 mm minijack in one end. (mono or stereo, the stereo might even give you twice the range :-) Cut it to 1/2 or 1/4 wavelength (or use as it is, it seems any length is an approvement). Of course a 90 degree plug and a bit stiff cable to keep it erect is preferable. Plug into the connector at the side. This works in the same way as connecting a headset to an mp3 player with a radio acts as an antenna as well. I discovered this when playing with using a set of transmitter/receiver connected together as a relay unit. I got far greater range FROM the relay than from the first unit to the relay. The cable between the trans/recv worked as an antenna... I have not modified any units accd to your recipee, so i cannot offer any clue as to how much less range (if any) my solution gives compared to yours. Would be nice to know though. Goffen
Mar 29, 2007. 3:27 AMabortretryfail says:
Also... would it work if I connected a retractable antenna instead of a wire....
http://www.guenthoer.de/bilder/tv-10-1.jpg
http://www.thunderpole.co.uk/angie_fairbanks/right-ang-retractable.gif
.....and then adjust antenna length to fit the need?
Mar 28, 2007. 6:22 PMabortretryfail says:
Hi. I just got two of these and rearing to make the mods. One guy though soldered the antenna to the big hole on the right?
antenna mod by blp1979
Which is which and which is better?
Thanks!
Mar 10, 2007. 3:06 PMKnigJes says:
how did you decide to add the antenna to the transmitter instead of the receiver? Is one more efficient than the other? It seems as the transmitter will put out the same power no matter what, and the improved receiver antenna would tune the signal more effectively. Can someone confirm/deny this thinking?
Mar 3, 2007. 6:08 AMjanekm says:
Since I've now got three of these transmitters and only need one (It was easier buying the kits than extra receivers) I guess I'll give this a try ;) I presume the blue wire in step 2 is the same as the black wire in the following steps? The existing antenna is just that trace on the PCB ending in that hole I take it? Looks like this PCB was designed for taking an extra antenna anyway ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:babylonfive
