3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Increase the capacity (runtime) of your laptop battery.
Is your laptop battery dead?
Is the runtime not long enough to get you through the day?
Do you carry one of those huge external battery packs?
This instructable is intended to show how one may replace the dead li-ion/li-poly cells of a laptop battery and how one may increase the capacity of the battery by adding extra cells.
The reason why adding extra cells to the internal battery is suggested compared to carrying around an external battery pack is that for the same amount of cells in an external pack, the laptop can run significantly longer if those cells were used internally.
Step 1External battery pack? Rip it apart and never think of using an external pack again!
So what's the voltage rating on your internal battery pack?
What's the rating on your power brick?
Lets use my tablet computer as an example.
The battery pack is rated for 3.7v * 3 cells or about 11volts. However, the power brick outputs 20v.
I've bought external battery packs before and have calculated how long it should last using watt hours instead of amp hours. However, that was wrong. The battery pack would need to output 20v in order to power my tablet, thus the battery cells used to increase the voltage does not attribute to the amp hours, which is indicative of how long the battery pack should last. Thus, a difference of 9 volts is significant. That's about 2 li-ion cells wasted just to match the voltage.
Another problem with using external packs is that the laptop would think that it's connected to an outlet, thus is not so weary of watching how much power it drains. The power brick for my tablet outputs 2.5 amps, thus it is possible at times my tablet is drawing 2.5 amps from the external pack. However, the internal batt pack only requires an average of 1 amp per hour.
So what would one do in order to increase the runtime of one's battery pack? Forget the external pack, just add more cells to the internal one.
107 comments
1-40 of 107next »
Apr 1, 2012. 4:46 PMkingdalle says:
Hi, great post! I understand that the smart curciut needs constant power, but connecting it to new batteries, will there be any? Are the batteries charged from the manufactorer? Otherwise it will do no good in keeping the circuit alive when the removing the batteries. Thanks
Jan 29, 2012. 5:23 PMgmichaelt says:
If you can add a string of cells to an existing battery (in parallel, as described), it would seem reasonable to suppose that you can also remove a string once you've ascertained that the recent additions are, in fact, in it for the long haul. The implication of that supposition is that once you've added (and verified) cells as described in this instructible, you could go back and excise the original cells, moving the additions directly into the casing where the originals were. Correct? Caveats? Qualifiers?
Jan 4, 2011. 11:22 AMboostergold1 says:
Hmm... i have always been suspicious when my battery was holding a charge for several hours one day and then the next it quit working all together immediately as i was working on it. What a joke. Does this mean i didn't have to waste my money on a replacement laptop battery?
Oct 15, 2011. 10:05 PMvo_danh says:
I also have the same issue as Ted_lens. I opened mine up and all the batteries are 4v . (some are 3.98v). What is the cutting point on voltage that they will work or is my circuitry bad?
Laptop works fine plugged in. On battery it dies within a few minutes. Is this repairable? Do I have to buy another used cheap battery and steal the circuitboard? Are my batteries just too low if the requirements on voltage stability is too sensitive?
Apr 8, 2011. 1:35 AMerixpc says:
Being off the grid for 8+ hours sounds exciting. Instead of strapping on extra bulk and weight to the laptop battery pack, what do you think of adding a 4 wire pig tail connector (http://www.etrailer.com/Wiring/Spectro/9653P.html) to the existing pack and then connecting that to the DIY external pack with all those li-pos? Would that work? How long does it take to fully charge your 15 cell set-up?
Apr 19, 2011. 1:57 AMerixpc says:
Got it. Don't mix old wth new. All batteries should be new. Got it. External pack to cut down on bulk and weight is fine but don't use the pig tail connector. Solder the cord directly. Thank you.
Aug 9, 2011. 10:18 AMNoblenutria says:
Hey Harrison Ford could help me with this instructable.
Aug 9, 2011. 10:17 AMNoblenutria says:
If your battery is mostly discharged when you start doing surgery on it it wont catch on fire even if you short it.
May 20, 2011. 9:23 PMcharlieb000 says:
you said "connect the new pack to the circuit before disconnecting the original battery cells. " thats a little dangerous, no wonder you say bury in sand!!
the circuitry with the battery controls the charge speed because the cells heatup if charged to fast, and you are anticipating a blow up!
id recommend having a series resistor between each connection to the old battery (excluding GND) to limit current.
Apr 22, 2011. 7:53 AMtgrundle says:
Would it be possable to connect wires to the positive and negitive of the batteries ( before the smart circuit ) and run them to a connector in the side of the pack that way you could plug in/ unplug your extra batteries (circuit still has power for batteries in pack, external batteries can be added/ removed as needed, external pack can be connected to supply power to smart circuit while changing batteries in pack). And if so would the computer need to be off when adding/ removing external batteries?
Apr 22, 2011. 7:55 AMtgrundle says:
I forgot to say that the external batteries would be in parallel with the internal ones.
Mar 25, 2011. 5:29 AMbechard says:
i want to replace my batteries with some srt of self chargeing device for ex. the magnet motor coud i do this and how?
Mar 25, 2011. 5:28 AMbechard says:
Mar 14, 2011. 4:43 PMrmckinney says:
Did you have to cut a hole in your battery casing in order to the smart circuit, then?
Dec 16, 2010. 1:55 PMTed_lens says:
1st of all, great instructable! your instructable and some other sources made me confident enough to rip apart my broken laptop battery...here is the deal:
My toshiba batterypack broke down a while ago... symptoms were:
- battery only had power for +-10 minutes
- batterypack drew large amount of current when charging, resulting in 2 blown adapters before i found this out.
So I ripped this thing apart and found 6 us18650gr cells inside. these cells are unprotected and wired to some electronic board like a lot of batterypacks are. So i ordered 6 unprotected replacement cells which are being shipped to me right now.
however further testing of the old cells made me doubt whether the cells are faulty, or maybe if the circuit-board is defective.
- all old cells read out +-4volts without load
- under load they all give me about 3.7 volts.
could it be possible that the circuit-board screwed up here instead of the individual cells? would be uncool since, in that case i might have ordered some useless batteries. Could anybody share their thoughts on this?
Sep 22, 2010. 10:37 AMmartinlass says:
Hi xeijix,
Great Tutorial!
Can you tell me where you got the replacement Lithium batteries for you LS800? I have hunted the internet like a demon and I cannot find anything that seems suitable except the AA size.
Martin
May 16, 2010. 11:46 AMgrimgroper says:
 great tutorial!! i want to build one that will fit in my back pack and connect via a second cable.. so it will be huge, possibly 20 cells.
what would happen if they were unevenly discharged? say i unplugged the laptop drained the internal battery then plugged the back pack one in after. visa versa.
May 16, 2010. 4:26 PMgrimgroper says:
 so would it be possible to build the pack with its own smart circuit?
May 16, 2010. 10:05 PMgrimgroper says:
 okay yep that makes sense, so will i be able to use a different laptops smart circuit or will i have to use the same one as in the laptops original battery? i will connect some sort of relay circuit with a capacitor (to make an uninterrupted switch between batteries) to disconnect the internal battery when the external one is connected. this would e between the smart circuits and the laptop. i didnt understand, does the smart circuit control the recharge?(would i be able to recharge the second set of cells with a separate charging circuit rather than through the laptop, perhaps more powerful charger... )
thanks for you help..
its hard to find some one willing to give out advice on laptop batteries.
May 6, 2010. 10:10 PMy2j514 says:
So I went about doing this before I found your instructable.  I was replacing my dead cells from a tutorial I found online.  They did not however warn about the smart circuit needing power.  It was disconnected for over 2 weeks.  When I put the new battery pack in windows detects the battery at 0% and if i remove the AC power it turns off immediately (like you said the gauge is wrong).  Is there anyway to fix this?!?!
Thanks!
May 7, 2010. 3:49 PMy2j514 says:
I tried this.  Ran into a tiny snag.  You can not simply tell windows to "do nothing" for a critical battery - well that is you can not do it through normal means.  I found this online, and it allowed me tell windows to do nothing if the battery reads critical.  I then disconnected the AC and the laptop just died, its not communicating with the battery at all =(
What are my options?
To change the 'Battery->Critical battery action->'On battery' setting to "Do nothing" using powercfg.exe
  1. activate the power scheme you want to modify.
  2. open an elevated command console (windows key, type 'cmd' in start menu, press "ctrl+shift+enter", click 'continue')
  3. execute "powercfg -setdcvalueindex SCHEME_CURRENT SUB_BATTERY BATACTIONCRIT 0"
  4. your current power scheme will show "Battery->Critical battery action->On battery: Do nothing" despite the option being unavailable in the drop box.
May 7, 2010. 5:08 PMy2j514 says:
One trillion percent sure there s a charge.  Had it plugged in for a night before booting.  My multimeter reads a voltage.  When windows boots, it says the battery is at 0% and NOT charging.  Has to be the smart circuit.  Ill try connecting the known to be working old cells and see if it works suddenly.
May 8, 2010. 7:29 AMy2j514 says:
Didn`t work!  Guess the bloody chip is corrupt.  Aside from ordering a new battery, is there anywhere I can purchase a new working circuit board? =(
Apr 9, 2009. 9:16 PMcyz980313 says:
u said we could use lithium polymer battery, but the lipo batteries are really dangerous. if u over charge them, they'll catch on fire. i know because by r/c car was destroyed because of li po batteries. so i suggest that u delete that suggestion!
Mar 29, 2010. 11:30 PMhansonsux says:
There are classic lithium ion cylindrical cells, and Lithium-Polymer (Lipo).   Lipo's are actually safer as they contain less flameable liquid electrolyte.  As with RC stuff fires - I think it's more of these batteries taking alot of abuse.  Overheating, Overcharging, shorts, damaged in crashes, etc.  No way they should explode that violently in normal use in some of the pictures I've seen.  People have been holding Lipo's now to their face (cell phone) for some years now.  Explosions are rare, despite the media hypeing the few cases when defecticve batteries have gone off.
Oct 27, 2009. 5:43 PMj- says:
Inspired by this guide, and ignoring all safety warnings, I expanded my laptop's battery using some old dell battery packs.
sites.google.com/site/keyboarddriver/
Sep 29, 2009. 9:22 PMmasterchrisx3 says:
nice tablet pc what kind is it?
1-40 of 107next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:xeijix
