Step 7Re-Assemble Transmitter
1.) Secure the 6 back case screws with rubber washers (if not done already).
2.) Take up any remaining slack on the 22awg wire as you begin to draw the halves closer together. Carefully bend wire as needed and align so the on/off switch fits back in hole.
3.) Re-attach PCB using 4 screws (carefully align LED). You may need to give yourself a bit of slack on the 22awg wire to do this. Just push it back inside the housing a bit until you are done.
5.) Double check wires (make sure nothing broke...which happened to me more than once).
6.) Flip case over (so face is up) and insert TX push button (see pic below).
7.) CAREFULLY close the case, adjusting antenna wire as you are closing. Take your time with this step!
8.) Tighten all 6 screws on the back of case and we're ready to test!
Add Comment
