Introduction: Incredibly Easy Felt Laptop Sleeve
This felt laptopsleeve is really fast to make! Give it a go and let me know what you made of it :)
Step 1: Everything You Need
3mm felt (measurements in step 2)
Thread
Large liner
2 buttons
Lint or string
Chalk (to draw on the felt with)
Scissors
Needle
Binderclips
Sewing machine
Thread
Large liner
2 buttons
Lint or string
Scissors
Needle
Binderclips
Sewing machine
Step 2: Measure and Cut
Depth (or length) measurement:
Fold the felt around the laptop, approx. 2,5x the depth. My felt was a bit shorter, this way I could make 2 projects :)
Mark the felt with the chalk and cut.
Width measurement:
The width of the laptop needs a bit of extra wiggle room. In the second picture I added 1cm. This was enough for this very thin laptop. My sewing machine took qof 0,5cm while sewing. The total in cm is marked and cut. Use at least 2 meauring points for this.
Use the liner to check if every edge is straight.
Especially if the felt wasn't machine cut for you. The edge in picture 7 needed some extra love. With the end of the liner in the corner it is easier to mark a straight line and 90° corner.
Cut on the inside or outside of the line, not in the middle. This way your edges will be straight.
Width measurement:
Step 3: Prepare for Sewing
Fold the felt around your laptop and mark the inside edge. Secure with binderclips. With 3mm felt this works much better than pins :)
If you want your inside edge to have a finished look, wait with the binderclips and sew that edge first.
Step 4: Put That Machine to Work
Grab your sewing machine and sew around all edges in one line.
If you have multiple stitching options on your machine, choose a thicker stitch. Picture 4 shows the difference between a regular stitch and the one I chose. Picture 5 shows the pictogram of the chosen stitch on my sewing machine.
Step 5: Finishing Touches
Hide the leftover thread, by threading a needle and pulling it though the side of your project.
Measure where you want your buttons, mark and sew them on. Using a thick or double thread makes this a lot easier and faster.
Tie the ribbon or string on the upper button. Wind it around both and you're done! :D
Step 6: The Result
Very good job! Enjoy your hard work :)
