Indestrucible Plant ID Tags by ShadyGreenthumb
Featured
This idea is all over the gardening webs but here is my visual interpretation.  Thanks to Kim for photography and to Mike for my new oregano plant.
I find most Gardeners and Plant Lovers to be very sharing, very giving. They have snippers in hand ready to cut off a tip to share,  harvest seeds, or dig up plant babies to pass around. Identifying little cuttings as they grow into big plants is difficult sometimes because the ID tags wear off,  the Ink washes off or gets rubbed off or the tags simply get lost.  While this idea won't help you from losing your plant ID tags, this will help you keep the identity of your precious growing plant start for a long time.
All you need are some empty, washed aluminum cans, a pair of scissors and a ball point pen.
Step 1: 1) Pierce the can at the top and bottom.
1)  I used small kiddie scissors because that was all that was around but I think long, adult-size scissors would work. Use the point and pierce a hole in the sides of the can to separate the bottom and the top.  Today's soda and beer cans are not your Grandma's cans. Aluminum cans are thin these days. They are easy to pierce, easy to cut. I did not wear gloves at all but if you feel more comfortable wearing them go for it.  The cut-can edges can be sharp and there will be shards of aluminum flying during this project so protect your area.
mole1 says: Apr 9, 2013. 11:49 AM
Brilliant!! I hadn't seen this before...I'm clearly out of touch!
If you make labels for larger plants like trees I suggest using an S shaped wire (like # 12 copper from Romex) to attach the label (through a paper punched hole) so as not to strangle the branch. You'll need to close the lower part of the S to secure the label.
I used thin craft copper sheeting for labels maybe 20 years ago. Although the copper has lasted, it's gotten pretty crumpled over the years. I think your idea will work better. Thanks for posting the idea here!
marcellahella says: Nov 16, 2012. 9:33 AM
thanks!
TT2 says: Sep 25, 2012. 4:51 AM
That's quite usefull. Perhaps with a little bit of acrylic paint, you can make the letters stand out.
FreeTibet says: Sep 19, 2012. 12:02 PM
Great idea! The zinc markers that are sold commercially are always outrageously pricey.
jessyratfink says: Aug 18, 2012. 11:30 AM
Very neat idea. These would be great to stamp as well. :D
ShadyGreenthumb (author) says: Aug 18, 2012. 2:07 PM
Thanks! Do you know what else I've discovered? If you are creative enough to write on the backside, backwards, the embossing looks like a label maker! It's too bad I can't edit my Instructable. What kind of stamp would you use? To emboss it or simply mark it? PS I entered this in a Fix It contest. Please vote for it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
