Indoor Aquaponic/Hydroponic Food System
9,022
252
6
Posted
Introduction: Indoor Aquaponic/Hydroponic Food System
This gravity-driven, indoor aquaponic system can be built in an hour. It uses the Nitrogen Cycle to aid in maximum plant growth. This is a symbiotic relationship that benefits you in two ways-You grow edible plants & you can use edible fish, as well. Beneficial bacteria break down the ammonia & fish effluent, converting it to nitrites & nitrates that can be absorbed by the plant roots.
Step 1: Plan With Measurements
Here are all of the measurements from my initial sketch/plan. This is the initial plan, but can be adjusted to
specific measurements needed. With these measurements, total cost of system is around $200-$250, using all new materials.
Step 2: Base Frame
Start with the 2x3 ft rectangle, framing the bottom.
Step 3: Bracing
Add bottom(floor) braces & front, lowest shelf brace.
Step 4: Bottom Shelf
Add front shelf legs & screw shelf pieces on to them.
Step 5: Middle Shelf
Add middle shelf legs & attach shelf pieces.
Step 6: Top Shelf
Add top shelf legs.
Step 7: Top Shelf
Add top shelf pieces.
Step 8: Lower Braces
Add braces that attach the shelf legs of different shelves together for stability.
Step 9: Inner Shelf Braces
Add back shelf for optional 2nd tank(bottom tank collects sludge, top tank has the fish).Add shelf for aquarium tank.
Step 10: Make It Mobile
When completed to this point, you can (optional) add casters for easier movement(if needed).
(2"-3" rubber wheels work best)
Step 11: Grow Beds & Plumbing
Add totes with holes cut(for plumbing) in the totes
& cut lids for plant baskets & PVC pipes. Aquarium caulk is used around plumbing, to seal it from leaking. Uniseals work, as well.
Step 12: Add the Tanks/Aquariums & Pumps
Add 1-2 tanks/aquariums(5 &10 gal), 1-2 small pumps(lift
must be between 3 & 4 ft. for best results), aquarium gravel & any live aquatic plants.
Step 13: Choose Your Food
Add seeds or seedlings(leafy greens work great) & fish(FYI-Japanese shubunkins are very hard to kill and produce the needed ammonia to kick of the nitrogen cycle).
Step 14: Light It Up
Add/attach plant lights/bulbs for maximum indoor growth. Within 4-6 weeks you can be producing enough salad items to feed a family of 4. Enjoy!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    6 Comments
    Great instructable. This is a lot like ones I have built in the past. I used only one pump and placed the fish tank on the bottom. The drain went through a gravel filter just before returning the water to the fish tank. Worked great. I built mine for less than $50 using storage containers and 2x4 s
    How have you attached the pipe to the underside of the trays? Is there a lip on the inside of the tray which allows water to gather in the tray to the height of the fitting before draining into the next tray?
    The pvc has screw together adapters, sealed with aquarium caulk. Flood & drain kits can be bought for $10 at hydroponic retailers & they tend to not leak.
    Can you tell me what's the name/brand of these grow beds and how did you attach the pipes? Also how can I be sure that there won't be any leaks? Did you use something to wrap around the pipes?
    Flood & drain kits can be found at hydroponic retailers for $10.
