Indoor Eco Drum Snare Fire Pit - Lareira Ecológica
618
Published
Introduction: Indoor Eco Drum Snare Fire Pit - Lareira Ecológica
Eco Drum Snare design Fire Pit
REMEMBER - THIS PROJECT IS AT YOUR OWN RISK
INTERNALLY TO USE A FIREPLACE REMEMBER TO TAKE SOME PRECAUTIONS:
- NEVER USE FUEL PARTICLES COMBUSTION AS GASOLINE THAT loose, WOOD, ETHANOL - prefer CLEAN ALTERNATIVE TO ALCOHOL AS A FIREPLACE OR LIQUID FUEL FOR ECOLOGICAL FIREPLACES
- KEEP WINDOWS OPEN NEXT TO THE ENVIRONMENT IN WHICH YOUR FIREPLACE IS
- KEEP THE SAFETY OF YOUR FAMILY AND YOUR HOUSE HAS ALWAYS IN NEAR SECURITY SYSTEMS OF CAUTION (as fire extinguishers)
Step 1: Basically
- Buy in a junkyard, a circular steel to use as a platform under fire and stones, in the center of this sheet, you will weld a piece of steel pipe that will fuel its container, at this stage, weld plate with caution not to be spaces where the liquid could leak.
- Volcanic rocks help hold the heat generated by the fire of alcohol for fireplaces or liquid itself to ecological fireplaces that do not burn or generate particles and odors
- A grid to protect against burns
- Call your friends and have fun on a cold day
Step 2: Indoor Camp
Fun
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    2 Comments
    Nicely done. I like the way it turned out!
    However . . . do you really use this indoors?
    Thanks, glad you liked !!
    Yes, I use it inside the apartment yes, but always with caution and common sense, do not let the fire reaches an uncontrollable height, since the fuel tank is limited .... I avoid it leaves very close to objects that have high possibility combustion, such as curtains, wooden furniture, sofa, etc ....
    I close by some security systems to avoid any unexpected!
