Indoor Floral or Fruity Wall
908
29
Posted in HomeGardening
Introduction: Indoor Floral or Fruity Wall
I suggest you create a wall chart with recovery items
What you will need ?
  • Recovery pot (plastic bottle, tin can, glass pot etc...)
  • Fabric
  • Iron wire or rope
  • Soil with compost or other natural boost for plant
  • Fork
  • Washi tape
  • peint brush
  • Plant of your choice
  • Wood glue and Water
  • Pliers
  • Diaper (what ? yes, diaper...unused diaper)
  • All necessary to hanging pots on the wall
Step 1: Planter's Embellishment
We'll cover fabric pots
  1. Measure the height and circumference dimensions of your container
  2. Cut the fabric according to your measurements
  3. Mix the glue with water (half / half)
  4. Glue the back of the fabric
  5. Cover the container with fabric
  6. Put glue a second time
  7. Let dry
Step 2: Creating Ties
  • If you have glass jars, create a clip with wire.
  1. Go around the pot with the wire,
  2. you kink the 2 ends at the base and along then you make a loop (see photo)
  • If you have iron or plastic boxes, create a tie with string.
  1. make 2 holes,
  2. pass an end of the rope in each hole
  3. tie a knot at each end to hold the rope
Step 3: Fork Hook
  1. Take a tweezers to tweak the fork's teeth : Use your imagination
  2. Take a big pliers to twist the body, you have to bend and after half
  3. To hang the fork you can:
  4. Put the screw between two teeth (like i do) or, drill a hole,
  5. Drill the wall and fix the forks
Step 4: Seed Plants
You will need:
  • Plants of your choice
  • brown cardboard
  • soil with compost
  • Diaper
  1. Prepare the media :
  • Retrieve the absorbent gel on the diaper
  • Mix with potting soil
  • Soak the plant in water at room temperature to break the clod
  1. Put brown cardboard at the bottom pot (it used to absorb some excess water and feed the plant)
  2. Cover with soil layer put the plant and fill with potting soil
  3. According to the plant and the pot, there may be no soil to add, in this case just put the gel
The gel layer serves to absorb and retain water : this will prevent you from drowning the plant and in addition you will have less need to water
Step 5: Decorate
  1. Hang the pot on the wall
  2. Put washi tape around the pot on the wall to do like a tableau
Et voilà ! You make it ! Enjoy !
You can use :
  • Strawberry for a fruity wall
  • Flowers for a colored wall
  • Seasonings for a perfumed wall
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    2 Comments
    I LOVE the fork hangers!! This is so creative!! Can't wait to see what you make next!
    Thank you !!!
    Il love to mix several ideas i find on the web to do something personnal !
    I'll do my best fo the next instuctables ;-)
