Building and flying your own airplane has always been high on the list of dreams of adventurous souls. Learning to build and fly the indoor paper airplane walkalong glider is a first step, off the grid and constructed from reused materials.
This instructable incorporates improvements on the Paper Airplane Walkalong Glider instructable. The improvements are as follows:
-Lighter paper- phone book paper instead of copier paper for slower speed and increased maneuverability
-Change in dimensions of initial sheet of paper (22cmX27cm) for pitch stability
-Central fold adds dihedral for better maneuverability
-Leading edges folded downward for softer stall characteristics
-Wedge cut out of tail section for reduced tail weight and better pitch stability
-Wedge fold in tail section for increased drag and slower flight
Please see the web page on Controllable Slope Soaring for more walkalong glider designs.
Remove these ads by
Signing UpStep 1Construct Ballast assembly
The ratio of dimensions of the rectangle are important for ensuring the correct washout angle in the wingtips (changing the ratio will change the distance between the leading and trailing edges relative to the width of the wingtip).
Or if you uploaded the videos to instructables in WMV format.
I cannot complete this instructable unless you do this :(
Hope this answers your question.
