I made it out of plywood, 2x4's, MDF, screws and paint for just a few hundred dollars.
After a few sketchup drawings, room measurements and some internet research on castles. I came up with this original design.
The build took a few weeks because I was designing and constructing during those precious few weekend hours during the boys nap time.
Remove these ads by
Signing UpStep 1Walk through
The top level has a nice large carpeted play area that leads you across a bridge giving access to the tower with fireman's pole. (Picture 2)
In the tower foam padding lines the hole and side walls with a custom made pillow fitting around the pole at the bottom. (Picture 3)
After sliding down the pole you find two built in shelves in the tower for storage and a side entrance to the main castle hall. (Picture 4,5)
Inside the main hall we have a nice dragon tapestry covering the back wall and a medieval looking mirror. (Picture 6) Just inside the front door is a push button light switch that controls the inside string lights and outside torch lamps. (Picture 7)
The front has two plastic torches that actually flicker for a great effect. A wooden shield is attached above the main door which was saved from my childhood. The tower has two long thin windows resembling the archers windows used in real castles.
52
comments
Add Comment
| 1-40 of 52 | next » |
Stryker (author)
says:
Stryker (author)
says:
Stryker (author)
says:
porcupinemamma
says:
porcupinemamma
says:
Stryker (author)
says:
The Porsche Fan
says:
The Porsche Fan
says:
Stryker (author)
says:
porcupinemamma
says:
skunkbait
says:
Add Comment
