3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Indoor cheap mini air plant holder with light reflector, humidity tray and plant label
There are two basic needs an air plant always require, that is high illumination and air flow with high humidity, both of which are not found indoor. Oftentimes those who kept air plant indoor always prefer the comfort room as a suitable place. What about if we want to display and enjoy our air plants in the living room and we dont have time to spray or soak them in water often. The only solution is to buy expensive humidifier that is both maintence worry and a burden with our electric bills.
I developed this instructable to enable air plant grower, place their pride collection in any area without the worry of not meeting the least possible requirements for the plant, although i do advice to use near but not close a south facing windows for the light requirements.
The humidity tray is just a method to prevent fast moisture lost and prolong the interval of soaking the plant, but it is still advisable to deep the plant in suitable water every two weeks.
The Plant belt makes it easier to remove the plant for soaking then returning it with drips safely collected in the humidity tray.
The CD at the back reflect and collect light in different spectrum for extra illumination.
I did use the same method for my mini orchids and its doing fine. I dont even have to water my plants everyday. The moisture produce from the evaporating water of the humidity tray is enough. Sometimes I use Orchid Fertilizer with water to feed flowering plants.
AIR PLANT or TILANDIAS are actually plants that thrive on air moisture and sunlight (Epiphyte). Instead of using roots they actually absorved water via their leaves.
In nature they are mostly found attached in trees, objects and rock walls using a system of false root to secure themselves. They are found in temperate location where there are lots of moisture.
Step 1Gathering Materials and tools
Most of the material being used are recycled, but i did spend a little for the Pentel Pen 15 pesos each Php. cost 30 pesos and for the double adhesive which cost me 20 pesos. The plant label was from a plant I previously bought.
Main Material        Tools
1. Empty Powder case or simillar                                    1. Scissor
2. junk CD silver base                                                        2. Red and Blue Penter, water proof
3. Hanging plant label                                                        3. Double adhesive
4. piece of Colored Cotton cloth
5. used lace or ribbon
6. Small plastic leaves or as prefer
2 comments
Oct 3, 2010. 3:13 PMCriket says:
(removed by author or community request)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bonglim72(bonglimbarbershop)
