Industrial Candelabra
3,352
139
10
Published
Introduction: Industrial Candelabra
A fun creative way to change the lighting in your home. Ideal for office, workshop, or night light
Step 1: Materials
2 Servalite
2 1in x 3/4in Black Reducer Coupling
5 3/4in Black Tee
2 25w Tubular bulb
1 6ft cable
1 Lamp light switch
1 Oatey pipe joint compound glue
1 Roll of electric tape
4 3/4in black cap
1 3/4in hose bibb
9 3/4in black steel pipe nipple
8 3/4in black 90 degree street elbow
2 wire connectors
Step 2: Screw Pipe Nipples
Place pipe joint glue on one end of all 8 steel pipe nipples and screw into black tee, as shown above.
Step 3: Electrical Cable Insertion
Screw electrical cable into servalite.
Screw black tees to hose bibb as shown above.
Step 4: Continue Cable
Insert electrical cable through black tee and reducer coupling
Step 5: Continue Cable
Continue connecting until all pieces are used.
Step 6: Connect Ends
When finished connecting tubes separate cables and connect each end from each wire.
Add another wire to each end using wire connectors, this wire will connect to the lamp light switch (use electrical tape around wires for double protection)
Insert all wire connectors into the tee.
Step 7: Screw Hole in Cap
Make a hole in one of the black caps and insert wire.
Screw cap to the steel pipe and pull wire through.
Step 8: Separate and Cut Wire
1 foot from the lamp separate wire in two and cut one.
Using the wire that was cut wrap each end to both of the screws in the light switch and place the uncut wire in the space above.
Step 9: Finish Switch
After putting the wires through the switch, close switch and pull through wire.
Connect end of wire to plug, now your lamp is ready to use!!!
Step 10: Complete
Step 11:
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    10 Discussions
    what size of seralte did you use how did you keep then in the reducer. I find one with too large of a base to use.
    Nice innovative idea, however I wish you had used LEDs rather than those inefficient room heaters.
    What a clever use for a faucet. I am faving. thanks for sharing your hard work and do have a splendorous spring!
    sunshiine
    great look,
    did u buy the materials online if so can u send the link?
    nice works
    That's awesome! I love the industrial look! I also love how you laid all the pieces out for us to see :)
