iImage Information
This is an easy and cheap industrialish picture/poster frame I came up with a while back - it uses 1/8" thick 3/4" wide flat aluminum stock and some little alligator spring clamps; all of which you can pick up at Home Depot and the like. I've used this on larger (20"x30") pictures but here I'm showing some smaller prints, whatever the size the method is the same.
Step 1Parts
- 4’ of 1/8” thick 3/4” wide flat aluminum stock | Home Depot, etc.
- Alligator spring clamps | Home Depot, etc.
- Parts cost - ~$13.00 | enough to do 3 8”x10” pictures
Note: the picture that is being framed is a slightly modified version of this iStock vector illustration.
I bough the image from iStock and I though I have a copy of it I can't distribute it in the manner your asking me to. You can grab a copy for yourself from iStock for cheap.
If you look at the pic you can see that you can't see the nail at all. Unless the picture was hung closer to the ground no one would see the nail.
But like you say, framing both preserves the artwork and gives it a bit of a sense of presence and value.
You may have only spent $10 to print the piece, but putting a frame on it can make it look like it is worth $100. The value of art goes far beyond the mere cost of materials. Preservation is important: you can easily print more copies, but who will print more when you're gone?
You could maybe justify a $100.00 frame if you said it was the labor of making the frame but I can guarantee you that there is not $100.00 or even $50.00 worth of materials in that frame. Frames are one of those products that are grossly overpriced.
I would sooner cut my heart out with a spoon ('cause it's dull and would hurt more) than spend $100.00 to frame a $10.00 print. Unless that print is a one-off, priceless, irreplaceable, etc. then there is no justifying it.
