Introduction: Industrial Pipe Bookshelf and Shoe Rack
About: Former Instructables employee CHECK OUT MY WORK www.carleyjacobson.com
This industrial pipe shelf is the perfect project for any handy -- or non handy -- person looking to update their room. The shelf is quick and easy to install and its hard industrial yet shabby chic look makes it a great addition to any room. All of the pipes have threaded ends which makes it really easy to update the shape of your shelf every few months.
I've seen similar shelves on etsy of the same size starting at $150. I made this shelf myself for under $70.
Step 1: Materials
Materials
  • (2) Flanges to mount pipe on the wall
  • (8) Wood Screws - size 12x2"
  • (8) 12" threaded pipes (1" diameter)
  • (9) 90 degree pipe elbows (1" diameter)
  • (2) 5" threaded pipes (1" diameter)
Tools
  • Hand drill
  • Drill bits
  • Pencil
  • Measuring Tape
Step 2: Mount Flange on Wall
Find a Stud:
You want to mount the flanges on studs so you will need a stud finder to help you.  I mounted my shelf in the corner of my room where I knew there would be a stud.  Check out these resources for finding studs:
Mount Flange:
  • Once you have figured out where you want your shelf to be, decide where you want to mount the first flange and mark the holes with a pencil where you will drill.
  • Drill pilot holes using a drill bit that is a bit smaller than the size of your screws.
  • Hold the flange up to the wall and screw the flange in with the hand drill.
Step 3: Attach Pipes
Attaching the pipes is pretty straight forward.  Screw the 5" threaded pipe into the flange.  Attach an elbow pipe to the end and start adding the 12" pipes.
TRICK: to get the pipes tight enough, after attaching the elbow pipes to the ends of the pipe, use the 2nd 5" pipe to tighten the connections.  The 5" pipe gives you more torque, and is helpful when you need to tighten pipes near the corners.
Step 4: Mount Second Flange
Attach the second 5" pipe to the second flange and attach an elbow pipe to the other end of the 5" pipe before attaching to the rest of the bookshelf.
Determine where the flange will sit on the wall (should be in a stud, if not make sure to use dry wall screws) and mark the holes where the screws will go.  Drill pilot holes using a drill bit that is a bit smaller than the size of your screws.  Hold the flange up to the wall and screw the flange in with the hand drill.
Step 5: Bookshelf
Lay your books upright or on their sides.  It may take some time to balance the books, but I found that as long as the book on the bottom of the stack was stable it was easier to stack the rest of the books.
Step 6: Shoe Rack
I think any girl can appreciate how fabulous this shoe rack looks.  I've always likes to display my shoes in my room (because I just love to stare at them).  I used to have them on a wooden bookshelf, but the bookshelf was too clunky and took up WAY too much space in my room.  Now that I've found this awesome solution I'm going to keep this pipe shelf to display my favorite shoes.
Furniture Challenge
Furniture Challenge
ShopBot Challenge
ShopBot Challenge
