Inexpensive DIY LED Lightbox for Tracing by designerik
Featured
As an Industrial design student, I often trace my rough sketches refine them into nice looking presentation drawings. I've been wanting to get a light box for a while now, but the ones commercially available are either bulky (with florescent tubes) or expensive (with LEDs).
On a recent trip to IKEA, I saw the "Dioder" LED set for about $25 and I got inspired to make my own LED light box at TechShop. All together, I saved over $100 by making my own and I had a lot of fun making it!
This is a great project for artists, designers, and photographers! It only took a few hours and it's something I will use a lot.
I made this at TechShop!
http://techshop.ws/ts_sanjose.html
Step 1: Materials/Tools/Equipment
Here are the materials, tools and equipment I used to make this project, there are plenty of other ways to do it so I'll try to suggest some alternatives along the way.
Materials:
- "Dioder" LED set from Ikea.
- 24" x 24" Sheet metal (Steel)
- 1/4" translucent acrylic sheet
- Something to make electrical connections (solder, electrical tape, solderless connectors, etc.)
- Powder coat or paint
Equipment:
- FlowJet waterjet cutter (You could also use the various shears in the metal shop at TechShop)
- Sheet metal bending brake
- Spot Welder (or something else for joining sheet metal)
- Laser Cutter (or table saw for cutting acrylic)
- Powder coat gun and oven
Tools:
- AutoDesk Inventor 2012
- PC
- Soldering Iron
lheffernan1 says: Dec 19, 2012. 11:30 AM
Can anyone make one for me please? Happy to pay the going rate. Please email me laheff@hotmail.com
matariki says: Oct 28, 2012. 9:33 PM
Could you use wood for the frame instead of sheet metal?
anniemo says: Jun 14, 2012. 11:13 AM
Why does the acrylic really need to be frosted (if using the pre-fab acrylic frame method)? Also, are the LED lights bright enough to see details when tracing onto a thick paper (such as arches, reives BFK or watercolor paper)?
ryber3 says: Jun 5, 2012. 6:32 PM
Awesome idea! I recently discovered Polaboys--a German-made LED lamp that looks like a huge Polaroid photo--but they're insanely expensive (like $3000!). Your idea has given me a great idea for my own DIY workaround though. Thanks!
WinbookXL3 says: Mar 2, 2012. 7:08 AM
Go to any sign shop that fabricates electrical signs and buy a few feet of
translucent white or diffusor white vinyl. Apply vinyl to inside of acrylic.
I would also suggest using .063" aluminum sheeting to build box
enclosure. you could also ask if the have old signs that you can salvage LED
moduels from.
jphphotography says: Mar 1, 2012. 12:09 PM
I made a larger one using wood and under counter fluorescent fixtures however I wanted to make a smaller one like this. A few years ago our IT dept was getting rid of scrap LCD monitors, they were pretty much giving away ones that had the backlights fail. I took one of the broken LCD monitors apart and found they contain a perfect diffusion panel. I've had it sitting around waiting for me to get off my but and make an LED version, maybe your instructable will be the nudge I needed.
kiwibum says: Mar 2, 2012. 12:50 AM
As soon as I saw this Instructable I thought of a couple of old diffusion panels I've kept from broken LCD monitors I've pulled apart. Kept them thinking they would make great light signs. As you say they would make great light boards too, another thing to add to my must do list. Thanks for the inspiration.
SOCmonkeybiz Cards says: Feb 27, 2012. 12:34 PM
Thanx for this instructable, you've got me already thinking of a cool workaround. I'm impressed with the sheer scope of your project! ...But for those of us w/out metal fabrication skills, I can think of a cool solution. Being a Graphic designer and photographer myself, having a compact lightbox like this would be ideal. So, I'm suggesting the use of an acrylic frame which can be bought @art supply stores or even a thriftstore or yardsale. It's essentially an acrylic box with a cardboard backing. Paint the inside of the frame white, tape in your LEDs and Voila! A nice home~made lightbox. : )
vintage53rose says: Mar 1, 2012. 8:33 PM
Thanks for the workaround. I thought I would have to search for a metal fabricator and pay him/her which sort of defeats the purpose
designerik (author) says: Mar 1, 2012. 8:58 AM
Yeah, I'm sure there are tons of ready made boxes and frames that could be hacked for this project.
wooac says: Feb 27, 2012. 10:31 AM
How's the color of the light? How does the IKEA LED strips compare to those $30 strips from Costco?
deathmango says: Mar 1, 2012. 8:00 PM
Another cheap option for lights is to buy a string of outdoor white led Christmas lights. I found a strip of 100 bulbs for 60% off pre-Christmas price. To get them shining the right way, I poked them through a sheet of cardboard, leaving all the wires underneath. Nowhere near as elegant as designerik's solution, but cheap, easy, and bright.
[edited for redundancy]
designerik (author) says: Mar 1, 2012. 8:54 AM
The light is a little dim, but it's pretty white. It produces plenty of light for tracing through two sheets of paper and I can "control" the contrast by switching my desk lamp on or off.
I'm not familiar with the Costco LEDs, but I imagine they would work just fine. I wasn't looking for anything special in terms of light color.
rickharris says: Feb 27, 2012. 12:31 AM
Your hole for the wire should have some protection for the wire or it will chafe through. A grommet is the normal way. You should also fix the wire on the inside to prevent pulling and subsequent damage.
otherwise good job.
For those who cant get translucent acrylic normal clear acrylic and be frosted with: A frosting spray used for windows, a solvent or fine grade sand paper (wet and dry ideally)
deathmango says: Mar 1, 2012. 7:54 PM
Good tips. I used a piece of tracing paper between two thin pieces of acrylic for mine, so that's another possible "frosting" route.
designerik (author) says: Mar 1, 2012. 8:57 AM
Good point about the hole and fixing the wire. I realized that while building it, but I didn't have the hardware on hand. I'll probably end up doing something like that in the near future. As this thing pretty much only moves from my desk to just next to my desk, I'm not in any big hurry. Thanks for the tip.
A light sandblasting is also great for frosting acrylic or glass.
deathmango says: Mar 1, 2012. 7:52 PM
This is a sweet, sleek design! I love your minimalist take on the project -- using so few pieces. Beautiful!
RAULRO says: Mar 1, 2012. 10:54 AM
I HAVE ONE THAT I MADE FROM A SHATERED MONITOR WORKING,
IT IS 41X23 CM. JUST I REMOVE THE SATHERED SCREEN AND DONE.
oscarfalcon says: Mar 1, 2012. 12:01 PM
Great idea...
sortiz1 says: Feb 27, 2012. 11:05 AM
I've been meaning to make a lightbox for a long time, and have LED's as a learning project for this year. Perhaps I can modify this guide for someone who is a bit short on snazzy tools/cutters.
designerik (author) says: Mar 1, 2012. 9:01 AM
That would be awesome. I tried to offer some alternatives, but i know there are lots of ways to do things. I know not everyone has a TechShop in their neighborhood (yet)
Texas1st says: Mar 1, 2012. 7:20 AM
What about using the self-adhesive frosting film that is used to cover glass windows? Also, i would splurge on a tempered piece of glass for the project. Frost it on the inside. The glass will clean easier than the acrylic and look nicer longer.
This is definitely something I'm thinking about doing as a project with my son. Thanks!
designerik (author) says: Mar 1, 2012. 8:51 AM
That's a great idea. I've also seen a spray paint for frosting glass.
dkolenda says: Mar 1, 2012. 6:40 AM
I know it's not DIY, but for $140 you could get a 6x6 Rosco LitePad
designerik (author) says: Mar 1, 2012. 8:49 AM
I looked at a few options, but I need something that will fit 11x17. They get really expensive at that size. This one cost less than $100.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
