Why?
Previously when you prepared food in my mom's kitchen you would be standing between the ceiling light and your work surface, thus casting a shadow. Additionally, under cabinet lighting tends to look nice. It's quite the dramatic effect in person and definitely stepped up the look of the kitchen a lot. It's less harsh of a light in person and significantly improved visibility while working in the kitchen.
Cost & Power Usage
I was able to light my mom's entire kitchen for under $40.00 including all parts. Additionally, the lights are quite power efficient, using about 3 watts per light tube (I used 6 pair / 12 tubes total). Total wattage=36 watts, or 3amps at 12V. This is a little over half the power usage of a normal 60watt incandescent bulb. Your final project price will vary depending on your supplies and the size of your kitchen.
Compare With and Without
1. Under cabinet lighting on, Ceiling light off.
2. Under cabinet lighting off, Ceiling light on.
3. Both under cabinet lighting on and ceiling light on.
Remove these ads by
Signing UpStep 1Collect the Parts
Details for a few of the parts are listed further below.
Parts:
1. Cold Cathode Lights w/ Inverters* (2 light tubes per inverter)
2. Power Supply (12V DC for these lights)*
3. Wire for connecting power to inverters
4. Staples or something else to hold up wires under cabinet
5. Power Switch (optional)
6. Inline Fuse (optional)
7. White Paint* (optional; see below)
Tools:
1. Wire Cutters
2. Soldering Iron
3. Solder
4. Electrical Tape
5. Multimeter
*Cold Cathode Tube Kits
I used white 12" tube kits from petrastechshop.com. They put out quite a bit of light and come on quickly. The light is less harsh in person than the camera makes it appear. They were on sale at the time for $3.75 or something. Shop around for the best price. Make sure the kits you get come with TWO 12" tubes and an inverter. Some places try to trick you with just one tube included for the same price. One of my tubes didn't light and I emailed the store and they sent me a working replacement which I received two days later.
*Power Supply
I used a HIPRO brand DC Switching Power Supply designed for a laptop. I got it from sciplus.com for about ten bucks. It's rated for 3.33A at 12V, aka 40W (watts = amps * volts). It gets quite warm as I'm approaching it's upper rating. Each individual lamp uses about 3 watts (6W for a pair) so total up your expected usage and get a supply over that. I am using 12 lamps (6 inverters) for a total of about 36 watts.
*White Paint
Before you start wiring things up, decide if you want to paint. If so, paint first so it can be drying while you work! Depending on how bright you want the lights to be and the color underneath your cabinets, you may want to paint under your cabinets to help reflect more light. I opted to paint the bare wood under the cabinets white to help with reflectivity so more light would reflect downward. This is entirely optional but it should help. Other colors may help soften the light, such as a pastel tan or yellow.
In a home and above your sink, even the regular stuff is not going to get clogged. You would need to do so much deep frying that everything else in the kitchen gets ruined also. :-)
GB (Gardner Bender) makes 3/4" cable plastic staples that mount
these cold cathode tubes perfectly. Use one at each end of the tube.
I swapped out the nails normally used to fasten the staples with
two #4 by 7/8" wood screws. Staples are white in color and are
part number PS-1575. You can get them at your local hardware
store for a couple of bucks for a package of 15.
I got these installed a month ago and I've loved it ever since.
http://www.ledshoppe.com/ledstrip.htm
For reference, incandescent bulbs put out light around 2,800K (energy star calls this 'soft white'), quartz halogen ~3,000K ('warm white'). Residential LED fixtures put out by major manufacturers tend to be 2,800K, 3,000K, or 3,500K. Commerical offices tend to run around 4,000K. The "daylight" bulbs put out around 6,500K.
The DOE solid state light website does a good job of discussing LED lighting: http://www1.eere.energy.gov/buildings/ssl/index.html
It looks like the inverter runs at 5 ma(rating on the website). So you should be able to run 660 sets on this power supply.
Or 40 watts / .06 watts = 667 inverters.
What am I misunderstanding here?
12 v x .005(5 ma) = 60 mw
http://www.svc.com/clk12wt2.html
Input 12V
Output 680V
Current 5 mA
So that's .005 A * 680V = ~3W. The current draw on the input side at 12V should be closer to 0.25A.
BTW, svc does charge shipping :( but has very cheap ccfl's. Dual 12" for $7, not nearly as cheap as the OP but still decent. I'll have to check out the link from this post though, sounds good.
