Inexpensive laptop stand / Notebook to Desktop convertor
I find myself using my laptop for long periods of time. It does get uncomfortable after a while. The keyboard and screen should ideally be separate to reduce neckstrain during prolonged use. If you are a full time laptop user, I suggest you build something like this that will help you raise your monitor to a near eye level. This way you can have both the keyboard and the monitor in the right positions.
Step 1A simple and inexpensive file sorter or desktop organizer solves your problem
I have a sturdy file sorter that I use to organize my desk. It has a wide base and 5 slots. It is also strong enough to hold my 8lb laptop.
21 comments
May 18, 2006. 9:49 AMbradclarkuk says:
Strictly speaking not really FREE is it?
lol
(_)
Sep 1, 2011. 4:01 PMjbrown2 says:
Yes free if you just go dumperst diving or check office supply stores for returned and broken ones. I have a friend that owns a supply house and he gave me, an older metal on hols up better then the plastic ones.
Aug 21, 2008. 6:34 AMAdmiral Puffinfresh says:
Lol did he say FREE? No, he said INEXPENSIVE. And if you already have one of those thingies, then in a sense, it IS free. =]
Sep 1, 2011. 3:56 PMjbrown2 says:
This is the BEST damn thing for laptops that I have ever seen, and the money saved on NOT having to buy a cooler can be used to buy more MONSTER drinks to play more games on the laptop.
This is a very good instruc.
Aug 30, 2011. 10:15 PMjfranzen says:
If you use the wire mesh one, you can mount a fan or two on the back if wanted.
Jun 9, 2011. 7:25 PMaxeman911 says:
i ahev the exact same mouse and keyboard, weird!?
Nov 10, 2010. 7:01 PMkmgater says:
I did this! Thanks for the idea!
It took me awhile to find one that wasn't plastic and slots wide enough to fit my laptop. My sorter is made of metal wire and I actually ended up breaking out a middle wire so the laptop could lean back. I use the front slot for my extra keyboard so I can get everything out of the way when needed and the light weight stand makes it easy to move everything over when I need to use the laptop.
Jan 29, 2010. 10:57 AMTrigger212 says:
Old Dell's can do this trick :)
Oct 21, 2006. 9:31 AMextratired says:
genius! the ones from the stores are so expensive it's crazy...
Jul 24, 2009. 1:05 AMKasm279 says:
lol, not at a thrift store ;D
May 8, 2006. 1:31 PMcarlsonmark says:
I was just about to do this when I realized that my laptop doesn't open wide enough to use this method :-( Cool idea though!
Jul 24, 2009. 1:04 AMKasm279 says:
what brand is it? thats just weird...
Mar 13, 2009. 2:58 AMlukkbox says:
your telling me there are laptops whos screens dont open all the way? hot dang! why would any designer do such a thing? i learn several new things everyday guess im spoilt having only ever owned IBM's, still a bit flabbergasted here
Oct 26, 2008. 7:22 AMzaman1995 says:
cooool
Dec 22, 2006. 12:30 PMvinisterz says:
cookbook standI found this cool cookbook stand was wondering can it hold my 15" dell.
Aug 21, 2006. 12:50 PMsanityfalling says:
you could just bend it to your tastes i dont think that would be to hard
Jul 27, 2006. 4:26 PMdeliman says:
This was the first instructable I used. Very clever! I used a wire file sorter I had lying around and it instantly helped my neck pain. Thanks!!!
Jun 24, 2006. 11:25 AMMagpye says:
I've been using something similar for over a year now (only found this site today). You can use a cooking book stand, which only cost a few dollars, and have a good stability, so the laptop doesn't tip over backwards. Most Dells and IBM's will happily open up to the 60 deg angle required for good viewing, though some Toshibas are a bit more arthritic I've seen commercial versions of this go for over $250. I think it's called The Oyster.
May 18, 2006. 6:40 PMsantiagoc says:
Some of you more skilled guys should make a similar laptop stand with hinges for changing the computer's angle (and thus height) to make it more comfortable for shorter/taller people.
May 9, 2006. 8:42 AMunclemantis says:
What make and model is that file folder? I am looking on staples.com and don't see much of them that have wide enough slots. I have a Dell Inspiron 1200. Will any file folder sorter work?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:zengineer
It's not about me
