Infinity Paper Clip Ring
7,299
5
Posted in CraftJewelry
Introduction: Infinity Paper Clip Ring
Learn how to make a ring out of paper clips!!
Step 1: Materials
Gather your materials (Two small paper clips, a pair of scissors, a pair of pliers, a marker, and a ruler).
Step 2: Unfold Paper Clips
Use your fingers and unfold the paper clips to make them as straight as possible.
Step 3: Original Length
Keep the first paper clip the original length.
Step 4: Cut the Second Paper Clip
Use the scissors to cut the second paper clip 2 inches long.
Step 5: Bend the First Paper Clip
Use the pliers to bend one half of the first paper clip to make a loop.
Step 6: Identical Loop
Then use the pliers to bend the other half of the same paper clip in the opposite direction and make and identical loop.
Step 7: Size the Infinity Sign
Play around with the infinity sign until it looks the way you want. The sign should be slightly bigger than the width of your desired finger.
Step 8: Cut Off Excess
Cut off any excess paper clip with the scissors.
Step 9: Shape the Ring Base
Use the second paper clip and wrap it around one half of the marker to create the shape of the base ring.
Step 10: Make Small Loops
Use the pliers to make small loops facing outward at the end of the paper clip on both sides.
Step 11: Hook on the Sign
Hook each side of the infinity sign into each loop on the ring base.
Step 12: Tighten the Loops
Use the pliers to tighten each loop on the ring around the infinity sign.
Step 13: Cut Off Excess
Cut off any excess paper clip off the ring.
Step 14: Mold the Ring
Mold the ring into a complete circle.
Step 15: Wear It!
Put the ring on your finger, and rock it! Enjoy!
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
