Visit my Blog http://microveleiros.blogspot.com
Remove these ads by
Signing UpStep 1Materials
Frame and rudder
3m PVC pipe 40mm Brown
6m PVC pipe 32mm Brown
2 elbows 40mm
1 T 40mm
2 T 40mm/32mm
2 elbows 32mm
2 connections threadable 32mm
4-bladed paddle plastic
Sail
2.5 m aluminum tube of 1 3 / 4 "
2 x 3m aluminum tube of 3 / 4 "
6.5 m ripstop nylon 250 or a 3 x 4m polytarp
sewing nylon line
A ring of 1 1 / 2 "internal diameter (metal, wood or reinforced plastic)
4 stainless steel clamps 3 / 4 "
Miscellaneous
Screws
Nuts
Washers
10m of 6mm rope
expandable polyurethane
Thank you very much
But when I raise the rudder, the boat makes a turn and crosses the line from the wind and I have a new direction.
Sorry my english by google, which has given hope to understand.
Julio
Canadian (open) canoeists who are really into sailing usually use a leeboard to make up for the fact that the boat has no keel- just a peice of shaped plywood which can be lowered into the water, don't know if this would improve your ability to tack ?
try googling open/canadian canoe sailing- there is a UK interest group out there.
ps your english is much better than my portugese! thanks for translating so well.
he has a gaff rig he has used with canoes, plus other boating adventures
although the koryak or chuchki people in eastern siberia used a tripod mast, with two legs on one gunwale, one on the other - it doesn't give much freedom of movement to a sail.
The sailing canoe using only a leeboard because the width is small, and only one is enough.
The PVC pipes I used are 40mm diameter and 3mm thick for my sail is strong enough, I believe in a canoe you will have more space to work.
Good luck with the project.
Julio
I think some of the canoe sailing guys use two leeboards- but not both at once! I missed the fact you were using leeboards in my first look at your set up.
I know there is some technical sailing type stuff about positioning of the lee board (or keel ) for best effect - I think it was in a book not online. You had to work out the centre of your sail and the centre of your boat and do some maths- or you can just experiment with moving the leeboards further forwards or backwards and see what works best.
I've only sailed properly briefly in Toppers- I know they are flat hulled (similar to your boat- and the best way to get them to move fast is to trim them as level as possible. In a canoe with the hull shape you can get them to plane by being stern heavy. You might get better effects by moving around in your boat as you sail- have fun playing!
The positioning of leeboards actually require complex calculations for the best performance, but as a rule, the amateur construction, we adopt the point of maximum power of the sail to be the point where it will be positioned leeboard. In my case I tried to use the brackets rowing, because of Jim Lucket SailboatsToGo I had suggested 30 "to 36"for use with the steering / oar in my boat and coincided with the brackets, to Rudder the distance should be less, then really think you should test some distances to get the best result. On the net you will find some sites on amateur building that can help with that.
Good luck
Good luck
Capone111 728=8B5, => O =5 <>3C G8B0BL 20H8 A>>1I5=8O.
Congratulations to you and your colleagues for their exciting and contagious achievement. I made a point to write in Portuguese because it is rare to see Brazilian videos constructive. (by google translater)
Julio
Well done
Ian
Thanks
In the video you look like you're getting some good speed.
Also, you can embed the video into the body of your instructable, might make it more accessible to the community here. The option is in the "rich editor" when you edit your project.
nice job!
Thanks for the tip of the video, I will correct.
Sorry my bad English, I have to use google translator.
