3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Infrared Intruder Alert
Step 3Build the Circuit
Build the Circuit
The circuit is designed so the photocell triggers the 6 volt relay which in turn closes the switch on the transmitter, sending the signal to the receiver and ringing the chime. I built it as small as possible because I wanted everything to fit inside the smallest Radio Shack hobby box.
3 comments
Dec 15, 2011. 3:14 PMgjscholtz says:
INTERRESTING PROJECT YET
I have several questions:
1 Is the 100ohm used as a limiting resitor for Receiver??
2 Why is it not used for the Transmitter?
- Is the Transmitter and Receiver part of the garage door system??
If it is then glueing the photocell over the Receiver will cause the garage door not able to work.
3 What energizes the photocel - How? What light source is used? since the photocel is glues over the Receivers 'light input' so not allowing to get any light from the Receiver!
I drew your diagram out on a schematic to be able to folow the circuit closely and as I can see it when the phtocell is energized [ I donot know how?] This will turn on the transister and in turn will turn on the relay!!!!!
I dont see the connection of the circuit in rlation to the Transmittter and Receiver!
I believe if you drew a schematic of the entire circuit I'm sure that your project would be much clearer to understand!
At lest for me - thanks
Jun 26, 2011. 1:45 PMtomtortoise says:
does anyone know of a substitute for the transistor i cant find them at radio shack or online?
Jul 8, 2009. 6:16 PMHighjump44 says:
can some one do a vid of them setting this up on a board and soldering it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2397
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
