Introduction: Ingrown Toenail Hack/Remedy
Picture of Ingrown Toenail Hack/Remedy
Home remedy for ingrown toenail
Parts
1. Ingrown toenail as a result of fungal infection
2. Hacksaw blade with 32 tpi. The high tooth count is important!
Step 1: Saw Nail Vertically
Picture of  Saw Nail Vertically
1. Using the hacksaw blade, saw several vertical cuts in the part of the nail deformed by the fungs. Be sure to saw slowly. If you feel a bit of soreness, stop at that point.
2. These cuts will weaken the nail so that when pressure is put on it via walking, it will have some room to move laterally. This movement will help stop the nail from driving into the skin.
3. The most important cut will be the one next to the point of the nail that is driving into the skin. It is at this point that the most lateral movement is needed to relieve the pressure.
4. Once the cuts are made, it will be easier to push a piece of cotton or paper under the portion of the nail that is driving into the skin to help bend it away from the skin.
5. Be sure to use a 32 tpi blade. The lower number tpi blades (like a reciprocating saw blade) have a tendency to rip and pull on the nail. A 32 tpi blade will saw into the nail without tearing into it.
6. Note that the cuts provide additional opportunities for anti-fungal cream to penetrate when it is applied.
offseid (author)2016-11-19
Nice info. I'm sure it will help SOMEONE out here!
matt392 (author)offseid2016-11-19
Thank you! It helped me. Plus it is helpful when it is causing intense pain and you need to relive it quickly.
CHRIS11556 (author)matt3922016-11-27
I'm happy it helped you, but I don't think you really want to relive the pain:) . P'S thanks to the instructabler.
About This Instructable
503views
4favorites
License:
Bio: Occupation: Tech Support
More by matt392:2nd Method - Using Hole Saw Without ArborUsing Hole Saw Without ArborBox for Raspberry Pi Model B and Power Supply Made From Wood Shims
Add instructable to:
