Introduction: Inline Berkey Waterfilter for 2 Inch Pvc and Water Barrels
Picture of Inline Berkey  Waterfilter for 2 Inch Pvc and Water Barrels
While out roughing it water is the most important concern.  So we put togeher a water filter system to gravity feed from one 55 gallon food grade plastic barrel to another.    The top barrel had a hole cut in the bottom side and a 1.5 inch pvc connecter installed.  1,5 inch was chosen for the upstream sections of the system because it is cheaper.   There may be more to come on upstream system development.
Step 1: Parts
Picture of Parts
One berkey water filter +
   -1/4 wingnut for threaded nipple(this one was a semisoft air filter cover plastic replacement wingnut)
one rubber or leather gasket
one 2 inch threaded pvc plug
one 1.5 to 2 inch pvc connector
one 2 inch to 2 inch threaded pvc connector
one 18 inch piece of 2 inch pvc
one 90 degree male to female (this may chage according to how you attach to your barrel)
Step 2: Drill Hole in 2 Inch Plug and Insert Wingnut
Picture of Drill Hole in 2 Inch Plug and Insert Wingnut
Yeah wingnuts are REALLY wondrous and useful.   Some of them don't seem practical but they are much needed.
Step 3: Put Gasket on Berkey Nipple and Screw Into Plug With the Wingnut
Picture of Put Gasket on Berkey Nipple and Screw Into Plug With the Wingnut
Step 4: Lower Threaded Couple Over Filter and Screw Into Plug
Picture of Lower Threaded Couple Over Filter and Screw Into Plug
Your thing should look like this...
Step 5: Slide 2 Inch Piece Over Filter and Attach 2 to 1.5 Coupler
Picture of Slide 2 Inch Piece Over Filter and Attach 2 to 1.5 Coupler
I knew we could do it!
Step 6: Add the Connector You Wish to Use to Connect to Your Barrel
Picture of Add the Connector You Wish to Use to Connect to Your Barrel
Yarrrgh,   yup that IS a pirate fish!
-bluegill notes:
Hey I like to use silicone sealant for some of the connections and yup it can get a little difficult to clean up when ya gotta fiddle the system.   SO THE BEST SEALANT TO USE has been a little beeswax mixed with cooking oil.   Or even bacon grease if you are critter kitchen.   I also like to put a silver spoon or other silverware in the upstream pipe...   It actually DOES kill microbugs...
-the fish, it swims
georion (author)2013-11-20
"""While out roughing it """
you haul along two 55 gal drums
and use """Why did you make a water filtration system with dirty pipe? """
just dont understand this.
rexmo (author)georion2014-09-14
and yes I do, especially when setting up a weeks long basecamp
not dirt, it's black silicone
Jackoffmanytrades (author)2013-03-26
Why did you make a water filtration system with dirty pipe? Also you could sink the clean water barrels on the ground like cisterns and it would allow algae to grow. It would also allow you to sturdy the layout up with it on that stump it might blow off and break. Just a few things I seem from the pictures.
rexmo (author)Jackoffmanytrades2014-09-14
what you think is dirt is actually silicone sealant
Also not good to use that metal fitting in their it will rust and leech toxins into your water.
current build has moved to all plastic, that fitting was used simply cause that's what was available
About This Instructable
6,245views
38favorites
License:
Bio: http://rexmo.net/#About_John_
More by rexmo:Inline Berkey  Waterfilter for 2 inch pvc and water barrels
Add instructable to:
