Inline Media Controls for Mobile to Car Audio
32,353
52
12
Posted in TechnologyAudio
Introduction: Inline Media Controls for Mobile to Car Audio
About: Trying my hand at everything...
This Instructable will show you how to create a 3.5mm male to male audio cable to use between your mobile phone and car to give you simple media control without having to touch or look at your phone.
I have only tested it with a Samsung Galaxy S2, and am not sure if it will work or be safe with any other models, although I have reason to believe it should work with many Android based phones, as the operating system should be looking for the same commands, assuming that the hardware supports it (that the phone has a 4 pole connection in its headphone socket).
EDIT:
Since upgrading my phone to the latest version of Android (Ice Cream Sandwich, v4.0.3) the controls have changed! My cord now does nothing when the button is pressed, volume up on skip track back, volume down on track forward. If anyone else finds this problem with their phone please leave a comment below with the phone version and operating system version. I am working on a new cable, but I have to try to find the new values to perform the desired functions!
EDIT 2:
I have tried resistance values from 0 ohm to 1200 ohms and have only been able to increase or decrease the volume on my Samsung Galaxy S2 running Android 4.0.3.
Decreasing volume occurs between 300 - 720 ohms
Increasing volume occurs between 150 - 290 ohms
The original values (used in this Instructable) should still work with earlier versions of Android, and possibly on other phones.
I don't think that this it will work with iPhones, as they look for a series of impulses rather than varied resistance as inline media controls.
I also need to give credit to WideBread.com and author Rich Kappmeier for doing the leg work on this one. Without his article
         http://www.wisebread.com/build-a-cable-to-control-your-android-phone-while-you-drive
I would not have been able to get very far with my idea (which as it turns out wasn't very original, at least in this phase).
At one point I forgot to take photos so I made a second cable to get photos of the final steps, thus the different cord colour.
Materials:
1 x 3.5mm 4 pole headphone jack
1 x 3.5mm stereo headphone jack
4 core cable
1 x 220 ohm resistor
1 x 620 ohm resistor
1 x push button (Play/Pause)
1 x 2 way switch (Skip Forward/Back)
Short length of wire
Solder
Sugru or other joining/finishing product
Car Audio Challenge
First Prize in the
Car Audio Challenge
Step 1: Striping the Wire
You will need to strip your 4 core wire.
My cable was very well insulated against chemical corrosion, far more than it needed to be for this purpose, which meant it was fairly hard to strip.
The outer jacket was a rubbery plastic which my wire stripper had trouble getting through without destroying the wire inside. After a few attempts I ended up using a sharp blade and bending the cable away from the cut and using the extra tension on the side facing up to make careful cuts till I got to the inner wires.
Only strip one end of your wire at this point. if you make a mistake you will need to cut it off and start again, making your cable shorter each time. Make sure you have plenty of excess cable and cut to length when you need to strip the other end.
This first end is going to be used for the 4 pole 3.5mm jack as it is the most tricky end of the cable, but more on that in the next step.
Step 2: Wiring the 4 Pole
The 4 pole 3.5mm jack is the end which goes into your phone.
The only jacks I could get where horribly cramped on the inside, with only a couple of mm to solder each connection very close to the others. Given the choice I would have gone for a 90 degree connector, because from what I have seen they are more spacious and have bigger connectors on the inside.
When you look at the internals of your jack you will see that, if it is like mine, it's very cramped. You will need to be careful to only expose very small sections of wire to soldier to the connection points, and to trim each wire to the appropriate length before soldering.
As marked in the Image 1 the connections are:
Top: Function
Mid Top: Earth
Mid Bottom: Right Speaker
Tip: Left Speaker
Long Arm: Earth
Furthest solder point: Left Speaker
Middle solder point: Right Speaker
Closest solder point: function
Your jack's connections may be different inside, so it's best to check them with your multimeter to make sure it's right. If you don't have a multimeter you can use a battery and a LED to make a circuit though the jack and find the continuity.
Keep your multimeter handy to check which pole corresponds to which solder point as you go, to get your wires connected properly. You don't want to have to unsolder the connections and try again if you have the same cramped connector I had.
Step 3: Wiring the Stereo Jack
The stereo jack, or 3 pole jack, is much easier than the 4 pole. Even with an inline jack it is more spacious inside the connector, but if you have a 90 degree one like I do (which I recommend for this use) it is very easy to connect on the inside.
The poles are the same as on the 4 pole jack, just without the function connection.
Top: Earth
Middle: Right Speaker
Tip: Left Speaker
Tracing that to the soldier points inside the jack is simple too:
Long Arm: Earth
Centre: Left Speaker
Non-centre: Right Speaker
At this point I also connected a second wire to the earth and ran it back out of the jack's housing along with the unused function wire. You could probably put holes in the housing and run these out the top or side to try to hide them, but I am intending to use Sugru to tidy things a little later on, and having them out the back keeps it out of the way for me to work on.
I am intending to mount my track skip switch to the back of the jack housing with the switch leaver extending past the end of the housing, and the play/pause button on top of the switch body, in line with the jack's poles.
At this point you can test to make sure your cable will work as a basic audio cable. Plug the 4 pole jack into your phone, and the stereo jack into your car stereo, computer line in, MP3 player dock or anything with a stereo socket that can play music, and fire up your favourite tracks on your phone.
It should play nicely through, if you have any issues with the connection you may only get one speaker working (indication the wire inside is broken or the solder point isn't connected properly) or no sound which could be the earth not connected, both speakers not connected or all wires not connected properly.
If you do find a problem, get your multi meter out and check the continuity of each pole to see which are not working, the open it up and try to find and fix the problem.
Step 4: Control Positioning
Using Sugru or an adhesive, position your controls where you want them.
For my set up I have the Skip Track control mounted on the back of the 3.5mm jack housing, and the Play/Pause button on top of that. Being careful not to block the motion of the Skip Track leaver or to jam up the button I placed enough Sugru around each to hold it in place and waited for it to cure (about 24 hours).
In the photo you can see I have already connected the resistors to the track skip control. That is because I had the switch wired up and ready to go, but trying to position it with wires connected was impossible. The tension in the wires was too much for the Sugru to hold before it cured. I disconnected the wires, but left the resistors in place. If you want to do the same read the next step before completing this one so you know which resistors to put where.
Step 5: Track Skipping
Once your Sugru has cured it's time to wire up the controls. Starting with the track skipping switch because in my set up it is on the bottom.
To skip to the next  or previous track I am using a switch which rests in its open position (not making a circuit), which is only connected to pins 2, 3 and 4. When pushed to the left it connects pins 1, 2, 3 and 4, and when pushed to the right it connects pins 2, 3, 4 and 5. See Image 1 for clarification.
I have connected pin 3 to the extra earth cable I ran out the back of the stereo jack housing.
Pin 1 has a 220ohm resistor soldered on.
Pin 5 has a 620ohm resistor soldered on.
Both the resistors on pin 1 and 5 are then connected to the function wire coming from the back of the jack housing.
When I push the switch lever left it connects the function wire through the 220ohm resister to earth and the phone knows to skip back. When pushed to the right the function wire connects to the 620ohm resistor and to earth and the phone skips forward.
Step 6: Play/Pause Button
The button I have for play/pause has 4 legs, and 2 pins for an internal LED. I don't want the LED, nor do I have a power lead for it, so I have cut the legs off to get them out of my way.
Checking with the multimeter which legs are connected only when the button is pressed I solder one to the function wire and the other to the Earth wire.
When pressing this button the function wire is Earthed with no resistance (or at least very little resistance) and the phone knows to play or pause the music (depending on which state it was in last).
As an added... bonus I guess, if you don't have a media player application running on your phone already when you press this button it will launch the default Android media player and start playing your music. Personally I don't like that, but if I can find a way to change the default player for my preferred one (Winamp) then it might become a useful feature for me.
My apologies, I didn't take a photo of the Play/Pause button before it was mounted to the other components. It's a fairly standard button.
Step 7: Over Moulding
To tidy up the cable a bit and cover all the currently exposed connections I used Sugru over the top.
Leaving the buttons and switch free I moulded the Sugru around the body of the switches and the stereo jack housing to give it a more clean, manufactured look, and to protect it against knocks and shorting out if it got bumped in the wrong way.
Sugru is perfect for this because it is non-conductive, easily moulds and has a good look when cured (depending on your finishing technique).
I also used a little on the 4 pole jack end of my cable as my connection didn't fit in the supplied housing properly and it bulged open a little around the connection, again easily fixed with Sugru.
The finished cable means I don't have to worry about pressing the wrong thing on my phone screen while driving, and makes it safer to operate while driving (as dangerous as changing radio station with a pre-set button). It also makes it more legal to use while driving as it is against the law to touch a mobile phone while driving in most (if not all) states of Australia, now I don't have to touch the phone to skip or pause my music.
Step 8: Final Test and Use
It probably doesn't need to be said, but use of the cable is quite simple. Plug the 4 pole jack in to your phone, the 3 pole in to the stereo. Press the play/Pause to start or stop your music, and flick the Track Skip leaver to skip tracks.
This could also be used to add an extension to a headphone cord with media controls. Change the 3.5mm jack for a socket and you can use it as a pass though for your headphones or speakers and get the advantage of media controls in line.
A note on testing this with your phone:
While I can't say for sure if it will work or not, or if it might cause damage to your phone, I think it should be fairly safe to try.
- If your phone doesn't support a 4 pole jack then the function wire becomes another earth wire (the connection inside the phone for earth is longer and touches both poles on the jack). If this is the case it will do nothing at all. Earthing an earth cable does absolutely nothing.
- If your phone does support a 4 pole jack but uses different resistance values, or even doesn't use resistance values at all and rather uses some kind of binary signal system for controls I don't think it will damage your phone because it is not supplying a higher voltage to the pins than already exists so your phone will probably just ignore the function wire if it doesn't know what to do.
- If nothing else the worst I can foresee it doing is the same as connecting a normal stereo cable to the socket and playing music through it to your stereo. any phone with a 3.5mm socket will have this ability, as it is expected that this is what the socket is used for.
I am not an engineer, and even if I where I do not work for every phone manufacturer in the world, so I can't say any of this with 100% certainty, but I was confident enough in my reasoning that I tested it on my phone (and working a minimum wage job I can't afford to replace it if something went wrong).
Doing this *might* void your warranty, but I doubt that as I don't think using third party peripherals is a voidable offence under any warranty I have ever read, but please check your phones warranty if you are concerned.
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    12 Comments
    Nice design, but technically speaking this is not really a "inline" control. That would be where the controls are somewhere in the length of the cable. Hence "inline". What would be interesting to see is if you could run the cable to the steering wheel and have the controls there. I think this would be safer as both hands would stay on the wheel.
    Inline control is any control of your media player (phone) which is on the audio cable. In this case the controls are at the end of the cable, but are still before the connector. Even if you ran more wire for the 4th pole and ground to put the buttons on (as you mentioned) the steering wheel it is still technically in line with the audio cable.
    While putting the controls on the steering wheel may be safer for use, having the cable long enough to allow full lock in both directions would require a fair amount of slack, this slack could inter fear with your driving and make it more dangerous than ever! The best solution for that would be to use a springy cord (think telephone cord) to keep it against the steering column.
    If you do decide to try that please do be careful with the cable, and make sure the controls on the wheel don't inter fear with your hands on the wheel.
    very cool. i have an android phone and was hoping play/pause wasnt the only thing i could do.
    im going to do this and mount the controls either on or by my steering wheel for easy access.
    also, this shouldnt void your warranty since you arent modifying the phone in any way.
    If you are planning to mount the controls on your steering wheel make sure you allow plenty of cable so you can turn to full lock without breaking the wires.
    I've seen that the Samsung galaxy note comes with headphones with inline play/pause, track skip and volume controls. If you can get your hands on the headphones from one of those you could measure the resistance across the 4th pole when changing the volume and add that to your controls too.
    I'm guessing that the volume control will be either one or two (ganged) pots simply attenuating the output, which is normally how they do it. IME just a single pot between the ground from the two outputs and the ground going back to the phone.
    Please comment if it's actually signalling the phone.
    Very nice instructable - Really useful but no CNC milling machines or laser cutters :). Thanks for taking the time to post it.
    Actually I think the volume control would be the same as track skipping, a specific resistance between the 4th pole and ground for volume up and another for volume down.
    The inline volume control used in simple headphones does use pots to change the resistance on the speaker wire, and thus the volume, but the idea of inline volume control in this case would be to change the setting on the phone. The only way the phone is receiving and input from these controls is via the 4th pole on the jack.
    If I can get my hands on a headset with inline volume I will try to figure it out and post my findings, however it is fairly difficult to find them these days.
    Check out:
    http://www.androidzoom.com/android_applications/tools/headset-volume-controller_jpyc.html
    The important bit seems to be:
    "Turn your headset previous/next buttons into a volume controller while playing back music. Pause playback and you can skip tracks again."
    Not great, but do-able. They don't do anything convenient like providing a DC offset to power tiny circuits with, do they?
    Anyone got an oscilloscope?
    Yarg - What happened to the formatting?
    Sorry
    I never thought about the volume, thats a good idea!
    I don't think many people do, the big manufacturers are all focused on Bluetooth accessories and simple things like this get missed!
    Luckily it's not very hard to do your self.
    Also don't forget to vote for it in the Car Audio competition if you like it!
