Innovative Knex Grenade
2,056
4
51
Posted
Introduction: Innovative Knex Grenade
This is the Newest knex grenade with sleek design and ultimate fragging with only one downside, it needs a spring, it will shoot the fragments to up to 6 meters depending on the spring (I used one of my crap ones and 6 meters is like 20 is feet which is totally awesome, with a spring like mine it will fire 23 shrapnel and a rod!!!! Time to build the awesome!!
Note: the only thin grenade that actually works, innovative and I fitted around 32 in my pocket so if you pop them all it might be better than the grenade by IaC
Step 1: Piece List
One thing that a knex 'ible needs!!
check the picts
Step 2: Joints
Build it, the spring must be bigger than the rod, duh!! but smaller than the spacers, I achieved this from a penspring by prying it wider and longer for better power!! you spring can get better from dragging it!!
Step1:attach it and place the spring on!!
Step2:put all the spacers on until it cannot get any further and still fit a y connector loosely
Step 3: add the y connector and place down so it is locked as shown
Step 3: Throw!!
1:prime it! read the yellow boxes
2/3:the disaster read the yellow boxes, it looks less than a few meters because my room is weird the bag thing is about 25 cm there and the camera thingy is about 60+ cm door and doorway is huge, my camera is just weird! and some shrapnel is further on
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    52 Comments
    This could be made even better if you made a bunch of them and attached them all to a central hub of 2 attached blue pieces, so it would explode absolutely everywhere.
    where did you find the spring?
    Between summer and autumn.
    No, I found it from a pen.
    Not bad, but if you use the spring that way it will lose power over time rather quickly.
    the picture was after the 100th time i threw it, could you rate please?
    Ok, I rate it a 4. Not that I would use this btw.
    why not? I mean it isn't that good, but it still works and gets the job done.
    Oh, and because I don't have a lot of spacers and just 2 springs.
    well my spring, amazingly came from te top of a 10 C pen
    10 C? What does that mean?
