loading
Step 5: Using the Insect Eavesdropper
If you've flipped it on and started listening to stuff, then you know it can be used for much much more than eavesdropping in on cricket conversations.  I point it to the highway and can hear cars with snowtires on.  I can hear creaking wood in the house and the sound of my feet scuffling across the carpet is deafening.
Make sure you use the volume knob judiciously.  It acts as sort of a squelch, as well.  Experiment and have fun.
What else can you use it for?
The high-gain amplifier I designed in this project is ideal for a variety of eavesdropping ventures.
  1. Replace the piezo mic with six to eight turns of 26-gauge magnet wire wound in a 3x5 foot loop and you can hear atmospheric noises such as lightening, the wind, even distant auroras can be heard with a high-gain amplifier.
  2. Replace the piezo mic with a 100-turn coil of 28-gauge magnet wire around a ferrite core and you can hear the wires buzzing in the walls and locate hidden wiring.  If you place a magnet at 40 degrees to the coil, you can hear nails under the plaster or sheet rock.
  3. Replace the piezo mic with a single loop connected to a diode and you can detect RF signals and use the high-gain amp as a "bug" detector.
  4. Connect a solar cell in place of the piezo mic and you can "hear light."  Point it at an airplane in the sky and you can hear it's strobe.  POint it at any light that has something periodically passing through it like a propeller or a rotary shaft, and you can hear the device.
I built it, but I must have done a mistake. Could you post a screen shot of your breadboard diagramm please?
Has anyone rebuilt this device yet? Don't get me wrong but this sounds just too great. Definatly gonna built it, but I would feel more motivated if someone in this forum has had success.<br>
<p>Hi FriXs,</p><p>You have some very interesting design ideas for your project. I can appreciate your skepticism about the device working as advertised, but I built two of them, both of the same schematics and PCBs that I've presented. However, I can't speak to the success of others. If you hear of any success or failures, or build the project for yourself I will look forward to reading about it! </p><p>Thanks for your comments!</p>
<p>I'm not qualified to comment on the electronics side, but on the acoustics, I would suggest that what is show here is likely not a parabolic, but a horn microphone. These are pretty rare beasts and tend to have issues of acoustic filtering (think of a horn tweeter reversed). It's not a terribly precise analogy, but a horn acts more like a funnel and a parabola as a reflector.</p>
<p>Hi David,</p><p>That's great information and you may be right there. Thank you for this thoughtful post and I appreciate the correction. I may see what other common household thing might be a better fit. Cheers!</p>
I found an even more precise mic (-70db) at conrad. Here is the link:<br>http://www.conrad.de/ce/de/product/302155/Elektret-Mikrofonkapsel-EM-4-Betriebsspannung-15-12-VDC-70-dB-Frequenzbereich-20-18-000-Hz-Inhalt-1-St?ref=searchDetail
I am collecting the parts at the moment but will use 9 microphones and make a collapsible Parabolic. If I use magnets to link the parts, will this effect the sound? Will there be more noise or just another frequency? (all magnets in same distance from the micros).
Good idea!<br> <br> I had trouble seeing the schema clearly so I've enclosed an enlarged one.<br> <br> Your comment about battery life got me thinking... Since you're just driving an earphone or two from it, why not skip the power amp, which is what's eating up the power.<br> <br> Try this experiment, connect the earpiece to pin-3 of the LM386 and see if you get a decent volume. Worst case is you change the 100k volume pot to a 1Meg one (the LM352 is good for another 10-20x gain). The 9-v should then last you a few weeks.
The resistor divider on the non inverting input of the 358 is part of the battery sucking culprit. <br>9v through 20kohms is 0.45mA doing nothing. <br>Make both R3 and R5 50k or even 100k and get more battery life. <br>If you're worried that may add noise put .1uF caps in parallel with each of them to shunt it and remove C2. Add 220uF parallel with those and remove C5. <br> <br>Now it's a nice Virtual Ground supply that takes the single voltage of the 9v and makes it look like +- 4.5v (actually 9v, 4.5v, 0v). <br>The 386 is capacitor coupled so all it sees is ac audio on it's input. <br>Even so the 386's output for silence is 4.5v. <br>Another 386 with inputs grounded could &quot;drive&quot; an active virtual ground instead of the resistor divider <br>Cool eh?.
Thanks for the tips and suggestions!
For a better view of the schematic, click on the &quot;i&quot; in the upper left-hand corner of the pic and select &quot;original image.&quot; It's pretty big and should be large enough for you to work with. If not, let me know.<br><br>As for your ideas, they sound great. I had originally designed it to work with an 8ohm speaker in a small handheld using the electret mic like the wongo-thingo in a star trek medical tricorder. Ha. I switched to headphones at a later stage, but you make a good point. I'll give it a burl and see how much output I get with just the power amp and the volume pot change-out sounds like a good plan B.<br><br>Thanks for the advice!
I can't get the files you attached to this instructable to open. What program opens them? Also, I am using a small tape recorder instead of building the circuit you show on this page. I tried the 3'x5' coils of wire but the unit is basically a short circuit to the mike input of the recorder. Shouldn't it have a resistor to match the impedance of the input?<br><br>Jerry
Hi Jerry,<br> <br> The files that are actually attached to this project are *.brd and *.sch (board and schematic) files that are meant to be opened with <a href="http://www.cadsoftusa.com/downloads/" rel="nofollow">CadSoft's Eagle Schematic and PCB Design</a> software. That's what I use for my schematics and to lay out my PCBs.<br> <br> Now about your impedance matching question...I apologize in advance if this is a review for you, but it may help other readers considering a clever project such as yours.<br> <br> The <em>impedance</em> of a microphone describes how&nbsp; much the mic resists the flow of an AC signal. Low-impedance is ~ 600 &Omega;.&nbsp; Medium-impedance is typically 600 - 10K &Omega; while high-impedance ranges over 10K &Omega;. So, the first step is to determine what sort of mic your recorder is designed to be used with. This will establish what sort of impedance matching circuit you'll need, or even if you'll need one at all. You really have one of three choices that I can think of: <ol> <li> Dynamic microphone <li> Condenser microphone <li> Electret microphone </ol> <strong>Dynamic Microphone</strong><br> These are often found in PA systems, hi-fi, and recording apps. When alternating pressure (that is, compressed air from a sound wave) hits the diaphragm, it induces a voltage across the leads as the voice coil accelerates through the magnet's magnetic field. These mics perform well over a broad frequency range and have a low impedance output. Some, however, have switches that allow for setting high- or low-impedance output.<br> <br> <strong>Condenser Microphone</strong><br> These mics offer exceptionally crisp, low-noise sound and are used for high-quality sound recordings. It consists of two charged plates (supplied from an external power supply) acting essentially like a sound-sensitive capacitor. A low-noise, high-impedance amplifier is typically required and also to provide low output impedance.<br> <br> <strong>Electret Microphone</strong><br> This is the microphone I used in this design. They are ubiquitous, low-cost, and easy to design with. They can be viewed as a specific class of condenser mics in that they have two plates, but one of them is an electret and provides its own charge. Power is normally supplied through a resistor (see my schematic). They respond best to mid- to high-frequencies and not well at all to low or bass frequencies, making them most useful for voice apps. Also, as the charge on the electret degrades over time, so does its performance.<br> <br> In general, it is advisable to connect a lower-impedance mic (source) to a higher-impedance input (destination, or just &quot;load&quot;), but inadvisable to connect a high-impedance mic to a low-impedance input. In the latter, a serious attenuation of the signal is likely occur. The commonly accepted heuristic is to allow the load impedance be about 10 times the source impedance.<br> <br> <strong>Impedance Odds and Ends</strong><br> So, is impedance matching necessary? Not typically when it concerns a low-impedance source connected to a high-impedance load. In the past, impedance matching was pretty important for power transfer reasons but with modern circuits and audio amps, what is most important is voltage transfer. For the most &quot;bang for your buck&quot; in voltage transfer, it was figured that the load should have an impedance of at least 10 times as big as the source, hence the de-facto standard I mentioned above. This is called <em>bridging</em>. Without bridging, matching same-impedance source and load results in about 6dB of attenuated signal loss, which is acceptable for most applications. However, in the opposite case of matching a high-impedance source to a low-impedance load, the signal attenuation would be equal to:<br> <br> dB = 20 log<sub>10</sub> * R<sub>Load</sub> / (R<sub>Load</sub> + R<sub>Source</sub>)<br> <br> As you can see, the signal loss is significant in this case.<br> <br> My suggestion is to try to get the specs for your recorder, if you don't have them. Determine what your source impedance from your chosen microphone will be and what the load impedance of the recorder input is. If you are &quot;rolling your own&quot; microphone like with the 3'x5' coil, calculate the impedance of the coil using the area and length of the wire and its resistivity using:<br> <br> R = &rho;(L/A)<br> <br> Where <em>&rho;</em> is the resistivity of copper,<em> L</em> is the length of the wire in meters, and <em>A</em> is the area of the wire (ie its AWG) in m<sup>2</sup>. To keep you from looking up stuff from different places, here are the specs for your 3'x5' 26# coil I mentioned in this instructable. You may have to tweak some of the values below as I'm forgetting some of my spring physics this morning. :)<br> <br> A = 26# AWG Area (m<sup>2</sup>): 252 * 5.067 x 10<sup>-10</sup> m<sup>2</sup><br> L = ~ turns * &pi; * D where D = 0.9144m &rarr; 6 turns ~ 17m, 8 turns ~ 22m (gross approximation: measure your wire by hand for best results)<br> &rho; = 1.72 x 10<sup>-8</sup> &Omega;m<br> <br> To ballpark it without doing the above, take note that 26# copper wire has ~ 41 &Omega; per 1000 feet so you're looking at something like 2 - 3 &Omega; if I did my math right (don't hesitate to double check me). Given this, if your recorder input/load impedance is 20-30 ohms minimum you probably don't need to impedance match.<br> <br> Hope this helps. Don't hesitate to post back here, email me here or jamesbl at research.cs.colorado.edu. And of course, if you build your project be sure to post it here on instructables and let me know. I'd like to see it! Good luck!<br> <br> Kind Regards,<br> Gian
Gian<br>Thank you for all the information. I will have to take all this information and do some adjusting to my project. One thing I want to make is a devise to change various natural sounds that and above or below the range of human hearing and convert to so I can hear it.<br><br>Thank you, Jerry
foxwoodfarm, <br> <br>I found your idea about shifting sounds into hearing range very interesting. Could we create some stegonagraphy here? No pun intended. <br> <br>Back in the early 90s, I had a program that could embed files of any extension into a faxed page. The faxed page would look like snow - noise - giberish. Receiver would think that it was an error reception. But, if you knew what it was, you could simply scan into your computer and the file(s) could be recomposed perfectly. I wish I could find the program - believe I have a copy somewhere lost in my attic. <br> <br>Anyway, could we do something like this with sound? That is - purposely float a message(s) in the inaudible range and then manipulate into useable form. Seems like would work best in the &quot;hiding in plain sight&quot; scenarios... <br> <br>Could cell phones &quot;hear&quot; this inaudible range?
bobzjr, <br> <br>If I'm reading you right, you can modulate many types of waves outside of the 2Hz-20KHz audible range (aka frequencies, aka carrier wave) with an input signal in the audible spectrum as a communication mechanism (as we do with FM (Frequency Modulation) and AM (Amplitude Modulation) radio signals). By necessity, the carrier wave is usually more energetic than the &quot;message&quot; signal modulating it. <br> <br>Something fun you might try is to take an AC signal in the audible range shift it up in frequency by mixing it with the signal from, say, a high-frequency oscillator. Physics states that when two frequencies are mixed you always get two signals: one at the sum of the frequencies and one at the difference. These frequencies are heterodyne pairs and the process is heterodyning, a common solution to shifting signals up or down in frequencies. <br> <br>If you have a random mess of logic IC's laying about your workshop, you may even try doubling the signal frequency by rectifying the AC with some diodes then shift the frequency back down into audible range with something like 4017 decade counter IC. <br> <br>All kinds of fun you can have! :) <br> <br>Gian
Hi Jerry, It sounds like you definitely have a fun project in mind. I'm not very knowledgable about infra-sonic transducers, but I have some experience with ultra-sonic transducers and frequency shifting and heterodyne frequency mixing to convert ultrasonic frequencies into the human-audible spectrum. I made an ultrasonic version of my &quot;Insect Eavesdropper&quot; to pick up cricket chirping in the &gt; 20 KHz range (mid-band ~ 40 KHz). I never published it here on Instructables.com, though, as I got busy and it just sorta dropped to the wayside. I've included two pictures, one of the complete schematic and one of an unrouted PCB board in hopes that these might give you some brainstorming ideas for your project.<br> <br> You've got a very fun and interesting project ahead of you from the sound of it. As always, best of luck to you!<br> <br> -Gian
oh, p.s. if these images are too small to make out the details and you have the Eagle schematic and PCB layout software, if you like, I'll be glad to send you the actual schematic and board files you can load directly into the layout editor.<br><br>Cheers!
How might you modulate an ultrasonic input down to audible frequencies? <br> <br>Insects and bats might be fun to listen to.
Howdy, <br> <br>Check out my comment above for how I suggest to do this. I also believe I include a schematic for one I built. <br> <br>Cheers! <br>Gian
On the bill of material you wrote LM368 but it's actually a LM<strong>386</strong>. The link is correct, though.
Sharp eyes! Thanks for noticing that. I've corrected it in the instructable now.<br><br>Cheers!
Hi, I'm making this right now, working with the black circuit diagram on my phone. could you tell me if polarity matters for the 0.1uF caps, they don't seem to be marked in the photo nor in the two caps i bought? also, for the 358 chip which is the right side up? sorry, beginner here.
Hi @DisappearingOak,<br><br>No worries about being a beginner. We all start somewhere and part of the fun of being a beginner is all that is open and new for you to explore!<br><br>Re: the 0.1uF caps, they have no polarity, so you can solder them in any way you like. As for the 358 IC, there should be a circle or dot (or maybe some other symbol) in one of the corners. That symbol indicates that when you orient the chip with the circle/dot in the top left corner, the top left pin is pin 1.<br><br>Hope this helps and good luck with your project!<br>-gian
i had a really old mic and i plugged it into my computer and i amplified it by like 30 db because it was really quiet and i could hear stuff on the radio, unfortunately it had a lot of static so you couldnt really understand what they were saying.
I went to Teacher Training College as a very mature student when I was forty to do Technical Teaching course. I didn't stand out quite as I expected for &nbsp;Ravenscraig Steelworks and Rolling Mill and a few ancilliary mills had been closed by The Great Thatcher so that there were more of my age than fresh faced youngsters just in from School. I enjoyed my four years having free run of several machine shops and laboratories. A second year metalwork project was making a lamp and special tools and patterns such as could be made in schools. I made a wall mounted lamp from polished aluminium shaped into a parabola along its length, held in perspex end mounts with large hollowed aluminium screws I cut on the lathe so that it would give a good light from two bulbs to illuminate my drawing desk. It now is above my bed. And there is where I would appreciate guidance from experienced parabola designers. For the lamp was not nearly as good at focussing light as it was at directing heat. This I found out after accidentally switching the lamp on when I was asleep and waking up part roasted and asking to be turned over so the other side could be cooked. Sound is a much longer wavelength than heat and travels slower whereas light and heat travel at the same speed differing in wavelength red being at the longer wavelength. Is there any way I should have corrected for the difference in the calculation of the parabola's dimensions to make it more light effective?
A parabola allways follows the formula y=x&uarr;2, no matter if it is used for light or sound (a wave is a wave, no matter what).<br>The ends of your constrution do not look to me as a parabola. If you know how to draw a function using the formula above, it would be easy as 1-2-3 to have the right curve you are looking for.<br><br>Good luck!
May I suggest scissors? Another tool which is great for poly bottles and even things as heavy as paint pails, is the PVC pipe cutter intended for plumbing. With a can-opener action you can get smooth edges without sawdust or melting.
That's true: you do get a good bit of melting when cutting the container and the pipes. That looks like a good thing to try Thanks for the tips!
The whole destructive-interference thing sounds really hard to tune correctly, since you'd have to get both the frequency and the phase exactly right. Have you considered a notch filter? I found a potentially useful circuit at http://www.kennethkuhn.com/electronics/ (the Hall Network); it's a notch filter you can tune with a single potentiometer.
After reading all the uses for it I really want one! It is so cool all the normally undetectable forces you can &quot;hear&quot; with this
Hello, Could you recommend a high gain amp kit? Thanks.
While I'm sure there are those kits out there (maybe Jameco or Velleman?), I am not familiar with any. Sorry I couldn't help!
For anyone interested in going further, check out some of the work of Dr. Rex Cocroft from U of Missouri. He discovered that bugs make much more sound that we can't hear by vibrating the plants that they are sitting on. He devised several ways to record that sound including using accelerometers and phonograph cartridges attached to plants. Here is some of his stuff:<br>http://www.npr.org/templates/story/story.php?storyId=5424281<br><br>Do a web search and you can find a lot more.
That's very awesome. There's also a book that's available called The Songs of Insects by Elliott and Hershberger that includes sonograms of tons of crickets and grasshoppers along with a CD so that you can hear each of them. It`s well worth it if you like this sort of thing.<br><br>Also, another point from your comment, is that an addition of an ultrasonic piezo with driver and receiver might be a good area to investigate. I've built the ultrasonic driver and receiver but haven't connected it into the parabolic design before. Would be a good project!<br><br>Thanks!
So, am I correct to assume that the better the parabola, the more amplification you can expect? Would a salad bowl work even better?
Yep, the better the parabola and the more closely you've put the mic to the intersection of the symmetry axis, the more focused the sound waves will be on your microphone, allowing you to pick up fainter sounds than without the parabola. I think a salad bowl would be an excellent candidate :)
Cool, that's what I figured. Hmmm, I wonder if my 3-year-old would like a bug listener? It would have to have two headphone plugs, of course...
I had considered putting the microphone on a metal rod and placing it in the ground and using RF wireless (say, sub-ghz range) to transmit the sounds back but my transmitter/receiver pair wasn't fast enough for real-time sound (maybe a sample-and-hold circuit?). The reason I had thought of this in the first place is that crickets get deadly silent when you walk into the middle of them with your Doctor Destro Insect 'Eavesdropper.<br><br>My brother and I were on the front patio pointing it at cars in the dark last night and trying to guess what type of car it was. I could hear snow tires, squeaky belts, etc. <br><br>The concern I would mention re: 3-year old is that the volume/squelch thingo on it can belt out some volume, especially at a full 9V. if you have the volume up high and listen to something close to the microphone it will clip slightly and you'll get a stuttering sound. It doesn't show up under normal use...it's just feedback. I'd consider putting a volume limiter or a window comparator to only allow volumes within a certain range.
Well that's why I'd have two headphone ports. One for her, and one for me - and I'd be controlling the volume!<br><br>You make a good point about frightening the bugs, though. She is less than sneaky when it comes to that sort of thing!<br><br>But a remote listening station sounds like a really cool idea! I wonder how it could be best implemented...
I've had some thoughts about this remote listening device...if you're interested in walking your (our) wits about a design shoot me an email. I've seen plenty of video over RF sub-gig so I can't imagine that it'd be too tortuous.
Nah, it should be easy enough. <br><br>I can't spend too much time on design at the moment though. I've just started up something epic and it'll require most of my attention...
Ah nice! I look forward to seeing this epic &quot;something&quot; sometime in the near future (if it's an instructable, that is).
It definitely will be an instructable - I just hope I can pull it off!
i have confidence in you...you've pulled off some pretty spectacular things so far, oh ye of little faith :)
Thanks. :)
have you guys heard of infrared headphones?<br>something like this but cheaper<br>http://www.dse.com.au/cgi-bin/dse.storefront/4c99a3e9019f978c2741c0a87e010710/Product/View/C4270<br>
That would require line of sight, which I was thinking that the mics on posts would probably be down in the weeds (say, a foot off the ground or maybe a little more), but that's not a bad idea at all. It would make the wireless reception a non-design issue and seems like it would be worth throwing another foot or two on the post with the IR transmitter on the top. I'm guessing it connects via an 1/8th jack or something? <br><br>I'll keep my eyes open for a cheaper pair of these things. Thanks for the heads up!
Very interesting. Your device is perfect to listen <a href="https://www.instructables.com/id/Mate-el-bicho-taladro-kill-the-wood-worm/">wood-worms!</a>
Now that would be interesting to hear!
About This Instructable
52,478views
184favorites
License:
Bio: Gian is a computational biologist and is the Managing Director at Open Design Strategies, LLC. He holds a BA in Molecular/Cellular Biology and an ... More »
More by nevdull:Create A Custom Medieval-/Fantasy-Style Calligraphy Quill Practical DACs Using Enumerated Types as Bitflags
Add instructable to:
