Inside-Outside Vase
Introduction: Inside-Outside Vase
Inside-Outside turning is a process in which 2 or more blocks of wood are glued together with craft paper (or newspaper) between each joint so that you can split them apart easily. Then once they are glued, the piece gets turned to a specific shape, sanded and finished. Then the glued up blank is split apart with a chisel and each block is turned 180 deg and permanently glued without the craft paper, re-mounted on the lathe and finish turned.
Follow along and I'll show you how I made this inside-outside vase with maple on my lathe.
Step 1: Gather Your Materials
I found a nice long stick of maple. I cut 4 blanks 1"x1"x9". These need to be square on all four edges. This required me to cut all sides of the blocks on the table-saw to ensure square.
Moving on...
Step 2: Glue and Clamp the Blank
Now its time to glue the blank together with craft paper separating all glued surfaces. I found it easiest to take two of the blanks and wrap the paper around 2 adjacent sides. That leaves 2 blanks without paper. glue them together and clamp it up.
It is extremely important to ensure these are glued square. There can be no slipping or sliding. So when you are clamping, place the clamp pads on the separation line squeezing all the blanks centered to one-another. once you have them held in place square, add a couple more clamps to get even pressure across the blank.
Wait about an hour and unclamp the blank. Tear off as much of the paper as you can and scrape any glue off the blank.
Step 3: Mount It to the Lathe
Now on the ends look for the center mark on the blanks (the point where all four corners meet). Using an awl, or a spring punch make a divot on each end in the center. Once you have the divot, using a 1/8" drill bit, drill the ends about 1/4" deep to define the center.
Now place the drive spur into one end and using a hammer, pound it in about 1/8" deep.
NOTE: If you have a 4 prong drive spur, make sure you don't place the blades on the glue lines. This will separate the blanks and ruin the project.
Now, mount the blank between centers on the lathe.
Turn the blank to the desired shape. DO NOT TURN THE WHOLE THING ROUND! leave at least 1.5" on each end square. This is what will be glued after the separation.
Once you have the desired shape turned, sand it all the way to 400 grit.
Then remove it from the lathe.
Step 4: Seperate the Blank and Re-glue
Now grab a chisel and a hammer and place the chisel blade on the line separating the blanks. Now, lightly tap the end of the chisel. This will split the blank on the lines without cracking the wood. Split all four blanks apart, keeping them in the proper order.
Now one blank at a time, turn them 180 deg making the outside of the turned piece the inside. Glue and clamp these together ensuring a good square glue-up. Also make sure the ends are flush with each-other.
Let this sit for an hour to dry.
Step 5: Finish Turn the Desired Outside Shape
Now install the 4 jaw chuck and mount the piece in the chuck at one end and bring the tail-stock up to the other end and tighten it in place.
Sharpen your gouge and scraper. I used the gouge and turned the blank round and shaped it to my desired vase shape.
Now its time to drill a hole in the tail end of the piece (the mouth of the vase). I started with a 1/8" bit and went all the way up to 1/2", using 3 bits to step up the hole. It is much easier to drill this 1/2" hole if you have a smaller hole to guide the bit.
Now using my round nosed scraper I finalized the shape and defined the mouth of the vase.
I then sanded the piece from 80 thru 400 grit.
Sanding this piece is a bit tricky. You can sand the entire piece like normal on the lathe, but the long skinny pieces require a bit more attention. I stop the lathe after each grit and hand sand the long skinny legs of the vase with the grain.
Finally, using my sharpened parting tool I parted the base of the vase from the chuck and removed it from the lathe. Sand the bottom up to 220 grit and get ready to finish it.
Step 6: Finish the Vase
I finished the vase by spraying 3 coats of polycrylic clear-coat (semi-gloss) sanding in-between with micro-mesh sandpaper.
You can get very creative with these pieces and they will always turn heads!
Thanks for looking!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    What a great project will have to have a go at this when my lathe skills improve and have alathe chuck for my lathe AWERSOM
    That's it, I'm buying a lathe. lol. Great job, very classy looking.
    ha! Don't do it... It will consume all your extra time and money!!! lol JK I love mine... you won't be sorry!!!
    How would I go about doing that? Would be the first time I tried to send a pic through Instructables.
    There is an add image button at the bottom of this comment window.
    I'll give it a try!
    Hey slicksqueegie im 14 and just got a wood lathe about 3 months ago. Ive gotten pretty good with it because my grandpa helps me, but neither of us know how to do experienced level stuff do you have any tips because you definitely know what your doing
    Check your messages. I'm still new to it, but will offer any tips my brain holds.
    Muy bonito, me ha gustado mucho.
    Very nice, I liked it.
