Anna's - Insta / Poly-Morphs Color Pigment Using Crayons !
763
8
6
Posted
Introduction: Anna's - Insta / Poly-Morphs Color Pigment Using Crayons !
I looked All over the Internet, but found Nothing -about using Crayons as Color Pigments for Insta / Poly-Morphs.
The suggestions were Alcohol based Pigments / Inks. Not to use Water Base. But, these cost money.
Why not Crayons ? - They are Oil based. - Like Old Crayons ... ?
Voila - it worked ... !
Step 1: Crayon Shreds / Pieces :
First, we cut off about 1/4in piece of Crayon.
This seemed to work for about 1 Tablespoon of Melted Plastic - say of 1in Ball size Plastic.
We used Red here, although it almost looked Brown.
The Darker Colors seem to give deeper Colors.
Then we diced the Crayon piece up.
Step 2: Plastic in an Empty Pot ...
We threw the 1 Tablespoon volume piece of the Poly Plastic into an empty pot ...
(No crayons yet !)
Step 3: Hot Water on the Plastic ...
Then, we poured hot water from a preheated teapot, to cover the Plastic ...
This seems to be the easiest method. Only need to swirl it around for about 1 minute.
Step 4: Melted Plastic ...
After 1 minute of swirling, the White Plastic - turns Transparent ...
Step 5: Roll the Plastic Over the Crayon Pieces ...
Next, carefully use a Fork to lift the Plastic out of the Hot Water.
And, Roll the Plastic over the Crayon bits.
Step 6: Crayon Pieces Should Be Rolled / Clamped Inside the Plastic ...
I found it best to Wrap the Plastic 'Fully Around' the Crayon Pieces.
So, that the pieces are 'Inside' the Plastic - to keep them from falling off.
Then, squish, Squish , SQUISH, ... !
Need to squeeze and mix untill it is uniform in color.
Step 7: Reheat to Continue Remixing ...
You will need to reheat , because it cools quickly.
Step 8:
After Squishing, it will turn uniform in color.
You may / will need to reheat a few times...
Step 9: All Finished !
This is the final result. We tried assorted old crayon pieces of Red , Blue , Yellow , Green.
The InstaMorp solidified fine like usual.
You may need to reheat and mix 2 or 3 times to get a smooth consistent color texture.
Used about 1/4" of crayon piece per 1 Tablespoon of Melted Plastic.
Great Use for Old Crayons ... !
- HAVE FUN !
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    6 Comments
    I have not used this plastic. Do you press it into molds? Do you sculpt it like clay?
    You can push it into moulds, or sculpt with your fingers/make impressions. You can't, unfortunately, sculpt like clay - its more like non-sticky blue tack when melted, texture-wise.
    If you want something like clay, my recommendation is something like "monster clay" - its like wax and clay, melts in microwave, reusable, and you can use clay tools on it. There are a few similar clays.
    If you are doing Molding, I would suggest using Plastic Wrap / Saran Wrap.
    If not, the PolyMorph will stick like glue. I even tried using Oil , but still had too much sticking.
    With the Plastic Wrap, you can also wrap a toy like a Plastic Dinosaur in the plastic wrap. Then use 2 clumps of PolyMorph to press on either side of the Toy. Make sure that the 2 clumps are also sepparated by the Plastic Wrap - else they will solidify together.
    You can then use these 2 Mold pieces, after hardening, to Mold more PolyMorph models of the original.
    Keep in mind, that the Polymorph takes longer to harden - as these large clumps.
    I looked into it. Monster clay seems like what I am looking for. Thanks.
    Very nice tip! I hadn't heard of this before.
    Clever idea. I am going to have to try this with some craft projects with my kids.
