loading
I decided to build a simple photo-booth as a fun addition for events, this goes through the basic steps of how i went from a few pieces of wood to a fully functional booth. I have also included a photo of what the images look like!
Please note that this photo-booth is simply a fan project. The photobooth is NOT endorsed by Instagram, and is NOT for sale!
Step 1: Cutting Wood
Square sheet of MDF, 600mm x 600mm with a Red Dome Push Button recessed at the bottom.
Step 2: Access Holes
Holes were then cut out for camera lens and tv monitor.
Step 3: Monitor Trim
A wooden frame was then fitted to surround the hole for the tv to add depth.
Step 4: Rounding Edges
Corners were then curved using a jigsaw.
Step 5: Fitting Sides
Sides were then cut just short of where the corners start to bend. Screws and 90 degree brackets temporarily attached them to the back piece.
Step 6: Building Corners
The rounded corners were made from short strips of wood, glued to form the rough shape of the corner. These were also temporarily screwed and attached using 90 degree brackets while the glue dried.
Step 7: Rounding Corners
Once the glue had dried on the rough corners, they were shaped using a wood plane and sander.
Step 8: Added Details
A recessed section was made on the front right, simply to add depth and additional detailing.
Step 9: Flash Holes
Holes were then cut to contain the 3 45mm seven segment displays, and two larger holes at the top for the flash guns.
Step 10: Shell Finished
The two holes for the flash guns were covered on the back with a hard translucent plastic to seal the unit and diffuse the light passing through, reducing the harshness of the light.
Step 11: Electronics
Wires were attached to each of the 7 segment displays, these were then covered using heat shrink and the 9 wires coming out of each 7 segment was then bound together using larger heat shrink to keep everything tidy.
Step 12: The PCB
There was a total of 28 transistors, 29 resistors a few meters of red/black wire.
Step 13: PCB Headers
PCB header plugs were soldered on to each individual seven segment display PCB. This allows them to be easily removed and replaced without having to work out the order of the pins every time, this also made troubleshooting easier.
Step 14: Finished PCB
The finished pcb, with the push button soldered in and a red LED light on the button, to control the camera a 2.5mm jack was soldered in and attached to a transistor, when the transmitter is closed, it connects the ground of the camera wire to the autofocus and shutter trigger at once. Note: the camera will be set on manual focus, therefore there was no need to have the booth autofocus beforehand, the only reason the autofocus cable is attached is because cameras will not allow the shutter wire to trigger them unless autofocus wire is already engaged.
Step 15: Arduino
The arduino (Blue part on the picture) is a microcontroller. Basically, you write code on the computer, upload it to te arduino and it will carry out functions.
In my case, i coded it to start the photobooth sequence once the big red button was pressed.
Here is a basic run down of what the code is doing;
Start -
[Press Button]
Red Button light switches off
Right hand side seven segment display illuminates with the number 4
Top two seven segment displays count from 10 to 0
Camera Triggers
Right hand side seven segment display illuminates with the number 3
Camera Triggers
Right hand side seven segment display illuminates with the number 2
Camera Triggers
Right hand side seven segment display illuminates with the number 1
Camera Triggers
Red Button light turns back on
All seven segments switch off
End
Step 16: Power/Support
For the power i wanted to use a standardised plug so it could easily be removed for transport. I used a kettle plug which was recessed into the base underneath the top hat of a speaker stand which i used for support. The reason for placing it under the top hat was so i could run the cable up the speaker stands centre post, meaning there was no cables dangling from the booth to get snagged.
You can also see the two 60mm 12v fans i used for ventilation. Due to the heat coming off the tv, flashes and arduino i wanted to prevent overheating, one blows cool air in, the other is reversed, sucking the warm air out.
Step 17: Hardware
The camera used was a Nikon d3200, and a 18-55 kit lens. I used 2 Nikon sb900 flashes to light the subjects.
One of the flashes was connected directly to the camera using a TTL cable and then the two flashes were connected using pc sync cable. Both flashes were set to manual power at 1/8.
The TTL cable was required so the camera knew flash was being used and automatically set the exposure for liveview, without this the brightness of the liveview would be that of the actual exposure settings. Basically, without flash connected liveview would expose at iso 100 f/11 1/30 (really dark on liveview indoors). With flash connected the camera would automatically choose the brightness of liveview using iso even though my settings were locked in at iso 100 f/11 and 1/60.
To mount the camera and flashes i made a simple bracket out of wood, bolts and some brackets.
You can also see the tv bracket below which held the tv in place.
Step 18: Finished Internals
Just a closer look at the insides of the booth once it was finished.
Top notch work! (and a really great instructable). This is one of the very best all- in one photobooth setups I've ever seen, and I work in the event industry. So cute and inviting. Your design and construction is just fantastic! A+
Hello, <br><br>I'm just getting things ready to make this but I'm a little stuck with the flash(es). I've managed to get a Nikon d5000 and a main power supply so that I don't have to worry about batteries, however I can't seem to find a flash with the ability to run from the mains. Has anyone else found this to be a problem, and does anyone have a solution? <br><br>I'm building it for my own wedding so I didn't really want to be changing the batteries throughout the evening. <br><br>I'm a newbie to flashes so any assistance would be appreciated. <br><br>Thanks
<p>How much would you charge to make this and ship to Romania?</p><p>Please email me at cristian.clazarescu@gmail.com</p><p>Thanks!</p>
great idea, inspired me to make my own version. pc build with touchscreen
<p>Per quanto riguarda l'interno della scatola di legno, visto che non sono molto pratica con l'elettronica ma vorrei provare a crearne uno mio, &egrave; possibile avere delle informazioni pi&ugrave; dettagliate dei prodotti da acquistare e il codice arduino da utilizzare? Grazie...Vi lascio la mia mail per contattarmi joly.86@hotmail.com</p>
<p>Thank you so much for this great Instructable. My version really looks like the original, don't you think ? ;)</p>
<p>Perfect work!<br>I wan't it, I wan't it.<br>I already ordered the Parts.<br>And the Arduino Code is almost ready, I think.</p><p><a href="https://123d.circuits.io/circuits/2061353-my-photo-booth-7-segment-remote-control" rel="nofollow">https://123d.circuits.io/circuits/2061353-my-photo...</a><br>I have to clean it up, but I hope the main functions are working.</p>
<p>I'm also building my own. Where did you find the speaker pole mount?</p>
<p>Great build. Can you provide the link for the pole mount? I can't seem to find it.</p>
<p>how much would it cost you to make it and ship it to the USA?</p>
<p>I bought my membership because of this project. I want to personally thank you for putting together such a detailed and easy to follow project. Your executions was fantastic. I'm already ordering my supplies and will share my pix when it's complete. </p>
<p>How much would you charge to make this and ship to USA?</p><p>c_arias10@hotmail.com</p>
<p>Hello!</p><p>How much would you charge to make this and ship to USA?</p><p>grecia021@hotmail.com</p><p>Thanks!</p>
<p>How much would you charge to make this and ship to USA?</p><p>Email is jnbb22@gmail.com</p>
<p>thank you for the Great Instruction. Mine is not that perfect as yours, congrats to the high quality work, but we have upgraded it with a direct photo printout on the back. That was quite positively mentioned by the guests.</p>
Hi would you be able to send me a detailed description of how you built this with the printout on the back?
Hi Rogers. Just like to check if u also do custom built for other. Also can you share your desing internal how to designed for prayer etc.
Hey there,<br><br>thank you for your interest. I can post some pictures and detailed comments if you wish to have. <br>The most problematic point that can prevent building custom style was the fact that I have used a notebook placed inside. This uses a licensed software that needs to be purchased after 30 days. It was good enough for my use, just one wedding, but makes it more expensive (if I remember correctly it was round about 300$).<br>If this and shipping from Germany wouldn't be a problem, I could do it of course ;)<br>I Try to take some detailed pics and post them.<br>kind regards, Kevin
Hey Rogers. It would be great if you can make me one and send to the UK. I would really appreciate the help / input thank you. Email - rhys@gregory.biz
Can you tell how did u attached the booth in tripod stand. Which part u used and when you bought it. I mean the mount which connects The booth and the light stand
Do u have Skype or other pm?
<p>Hallo Rogers, </p><p>Ich habe n&auml;chstes Jahr Hochzeit und leider bin kein DIY Person und w&uuml;rde wahrscheinlich so etwas nie machen k&ouml;nnen. K&ouml;nnten Sie ein f&uuml;r mich machen, nat&uuml;rlich werde ich das zahlen. Ich lebe in &Ouml;sterreich, also Versand sollte wahrscheinlich kein Problem sein.</p><p>Vielen dank! </p><p>Mit freundlichen Gr&uuml;&szlig;en, </p><p>Balazs Iosif</p>
Hi can you kindly help in providing dimensions / sizes detailed specs cutting the box
Hey There,<br>I just added my design drafts for you. The rest was done on the object ;)
Thank you for your kind help. Would you be so kind to email me the attachment to moisesjLL@outlook.com I can't view it clearly in your message. Thank you
<p>Can you tell me, what printer did you use??? </p>
<p>Hi,</p><p>It would be great if you can make me one and send to the INDIA and how much will be the cost!<br><br>VSTUDIOO@GMAIL.COM</p>
Hi, email me when you have time. Luv. Your wk! Boogielights21@gmail.com
<p>who sends me the project because I can not buying not having a credit card??</p><p>at this account tari.pantanelli@gmail.com</p>
<p>Hi,</p><p>I love have one this photo booth!</p><p>It would be great if you can make me one and send to the Australia and how much will be the cost!</p><p>email,</p><p>rnkingston@gmail.com</p>
<p>Very nice project:</p><p>Since I do not own an Arduino I used a Raspberry Pi as a controller just as in this project: <a href="https://www.instructables.com/id/Raspberry-Pi-photo-booth-controller/" rel="nofollow">https://www.instructables.com/id/Raspberry-Pi-photo...</a></p><p>I added a WLAN-Router for management purposes. I also made it slightly smaller in 500x500mm. </p>
<p>Great idea. So good that I had to make one myself. As I had no idea how to code the arduino I made a few changes. Mine runs off a laptop using the NKRemote photobooth software which is operated using the touchscreen. The booth will contain two flashes when operating but only one is shown in the photo. The button plays funny sounds when pressed (wolf whistle etc.)</p><p>In the software it gives the user the option to email their photographs. I did not intend on printing them. I can also add facebook upload but this will take a lot of time and probably cause queues.</p><p>I just have to wait until my wedding now before I can use it. I plan on printing the photographs to send as thank you cards.</p><p>I hope you like it!</p>
<p>How did you make the flashes link together </p>
<p>I am using yongnuo wireless flash triggers. Here is the link to the ones I am using on Amazon UK.</p><p><a href="http://www.amazon.co.uk/YONGNUO-YN-622N-TX-Transmitter-Wireless-Transceiver/dp/B00OXFFHQK/ref=sr_1_10?s=electronics&ie=UTF8&qid=1435236686&sr=1-10&keywords=yn+622n" rel="nofollow">http://www.amazon.co.uk/YONGNUO-YN-622N-TX-Transmitter-Wireless-Transceiver/dp/B00OXFFHQK/ref=sr_1_10?s=electronics&amp;ie=UTF8&amp;qid=1435236686&amp;sr=1-10&amp;keywords=yn+622n</a></p>
<p>Thanks That Helps</p>
Hi Alex <br>Would you be able email or Skype me please?<br>Alfieqs@hotmail.co.uk
<p>My version with a touch screen and barrel flash with constant light. </p>
<p>any chance you could provide a wiring diagram please.</p><p>If you post it, you gotta provide the Arduino code</p>
<p>Hi. it looks very well put together. I'm trying to build one myself. What tripod did you buy to support the weight of the booth?</p>
How are you attaching the light stand which party you used and where u bought it from
I do not have the tools time or the knowledge to do it myself. Can I buy a booth from you or can I ask you to make me one I have a different idea not in the shape of the instagram logo. Please reply to my email moore0036@gmail.com
<p>How big is this thing and can you supply a link for the code? Would love to add this to my DJ business.</p>
<p>Seems the OP is not responding to a lot of questions posted here in the comment section. Can we send him an email instead?</p>
<p>this is very creative &amp; i want to try it...however, i am just wondering about the image of the camera..would you get in trouble if your copying the icon of instragram?? please let me know coz im very excited to start building this.</p>
<p>I was thinking the same thing. Just have to be creative and make it your own. You don't necessarily have to stick to the instagram branding.</p>
<p>This is a stellar project! Very cool. Can you please provide the Arduino code? Cheers!</p>
<p>Sorry if someone has asked and you have answered previously... but can you tell me what light stand you used and what attachment is needed to connect the light stand to the bottom of the box? Thanks much!</p>
<p>Agreed. If you post it, you gotta provide the Arduino code.</p>
<p>It is cool. But how do we connect the camera to the screen? and the people can looks at the screen when they pose</p>
About This Instructable
430,892views
720favorites
License:
More by alexandermorris:Instagram Inspired DIY Photo-Booth
Add instructable to:
