Install 2015-up Ford Mustang LED Side Marker Light Lamps
Published
Introduction: Install 2015-up Ford Mustang LED Side Marker Light Lamps
About: Everything about automotive LED lights
This guide will show you how to install the 2015-up 6th generation Ford Mustang LED rear side marker lights. Ideal for upgrading your stock side markers, your tail end will be able to achieve a brighter, more vibrant look. This can easily be done with plug-and-play action.
Step 1: Release the Stock Side Marker Lights From Your Ford Mustang.
Reach from behind to undo the clip. We recommend using a towel to shield your hand and wrist from the hot exhaust or waiting for the exhaust to cool down so you don't burn yourself.
Step 2: Remove the OEM Side Marker Light From Its Stock Harness.
Pull out the side marker housing and twist/unlock the incandescent bulb from the base of the harness.
Step 3: Plug in the Rear LED Side Marker Light.
Make sure you tuck in the wires so water doesn't get into the wires and connector.
Repeat steps 1-3 for the other side.
Step 4: Final Steps
Test the Ford Mustang rear LED side marker lamps to make sure they fully function. Once you have, snap in the LED side markers to finish.
Enjoy your Ford Mustang's brand new set of rear red LED side marker lights!
Find this and more OEM fit LED lights at iJDMTOY.com.
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
