Install Brick
5,696
120
6
Posted in WorkshopHome-improvement
Introduction: Install Brick
About: Hey everyone! My name is Beau. I'm a father, a diy lover, and a partner in a construction company. I started learning the construction business at a young age. My dad, brother, and 3 uncles are all general c...
Quick instructions on installing brick. This is the down and dirty easy instructable on laying brick. I made another version, but figured I made it way to complicated. So, enjoy this version and let me know in the comments what you think.
Step 1: Tools and Supplies
1. Brick
2. Plastic Cement
3. Sand
4. Grinder
5. Shovel
6. Wheelbarrow
7. Mallet
8. Trowel
9. String Line
10. Level
11. Pencil
12. Measuring Tape
13. Ruler
Step 2: Make Plastic Cement
1. Take 6 shovel scoops of sand and mix it with your plastic cement.
2. Add water till it looks similar to the picture above. Try not to make it to wet because the brick will sink. However, don't make it to dry because brick won't stick to the cement.
Step 3: Set Up String Lines
1. Figure out your lay. It's usually best to start away from the building and lay towards it.
2. Set up your string lines and make sure it's tight. This will give you height and distance of where the brick should be. Beginners should start laying 3 brick rows at a time.
3. Hint: Adjust string line to desired height to allow a slope for water to drain.
Step 4: Lay Brick
1. Lightly wet down the area and your brick. This will help keep the moisture in your plastic cement.
2. Put enough plastic cement down to lay around 10 to 15 bricks. Smooth out the cement with your trowel.
3. Put a brick in position and hit it with the mallet till the brick is set at your height and angle.
4. Once you've laid 3 bricks across then use your level to ensure they are even.
5. Repeat.
Step 5: Make Cuts
1. Measure the distance for your cut.
2. Mark your brick and draw a line between the two points.
3. Take your grinder and cut your brick to desire length.
4. Install your cut.
Step 6: Congrats!
Congrats! You now know how to lay brick. I have a more detailed instructable on brick which you can access through my profile. Make sure to follow and I'll be having a concert pour and tile instructable available soon.
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    6 Comments
    I've used your method to install a layer of bricks near my pool. The company that provided the pool was very decent www.poolforconstruct.com , however they didn't actually include brick layering so I had to find a way to install it myself. Your tips and tricks really helped me thanks.
    Forgot to say how lovely your brick laying looks! Please add a photo to actually show the brick being cut. Also would be nice to see the cut brick laid in place. Beautiful work! Look forward to trying your instructions some day.
    Hey ERsearch!
    I made another instructable on how to cut those bricks. So, just follow my profile and that should help you with your diy project.
    Hey ERsearch,
    Thank you for the compliments. I'll be laying more brick tomorrow, so I'll make sure to post pictures of me cutting and installing the brick. It's hard to tell with the limited info if the grout needs to be cleaned or replaced. If you have pics then I can take a look at it for you. As for the tile that needs to be redone, you can use gorilla glue if the tile still sits leveled. The glue and the new grout should be more than enough to keep it in place. However, if your tile is not level then you'll need to carefully remove and replace the thinset. I'll try to make an instructable in the next few days to go over these situations for anyone that needs it.
    Please do you have any info on cleaning and redoing old grout between tile (on bathroom floor). An approach a weak sickly, ignorant but interested non-pro can do! A certain amount of the old dirty grout needs sanded or scraped out? Also, one tile has come out and needs relayed. PS I think the word is "trowel"?
