Install Ford F-150 18W Rear LED Backup Reverse Light Bars
168
Posted in WorkshopCars
Introduction: Install Ford F-150 18W Rear LED Backup Reverse Light Bars
About: Everything about automotive LED lights
This tutorial will show you how to install the 18W high powered LED backup reverse light bars on your 2015 and later Ford F-150 truck.
This rear mini LED light bar set will NOT fit the F-150 Raptor edition. Installation is clear-cut with no modifications required. Use this LED light bar set to achieve a bigger and brighter presence as you back up.
Step 1: Find the Bolt Under the Ends of Your Rear Bumper.
This is where you will install the mini LED light bars.
Step 2: Unscrew the Bolt Circled in Red.
Route the bolt through the offset U-shaped metal mounting bracket as shown.
Step 3: Bolt the Screw and U-shaped Support Mounts Onto the Unbolted Location.
Make sure that the legs are facing in towards your Ford F-150.
Step 4: Secure the Back-up LED Light Bars Onto the U-shaped Mounting Brackets.
Connect the wires to your reverse tail light harness. Repeat steps 1-4 for the other side.
Step 5: Final Steps
Test your LED backup reverse light bars to make sure they fully shine.
Once you have confirmed functionality, you can enjoy your Ford F150's new set of LED back-up reverse light bars!
You can find this and more off road truck LED lighting at iJDMTOY.com today!
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
