3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Install Heated Grips on Your Motorcycle (or ATV)
Step 7Press on the new grips.
Using your strength press the new grips into place.
1 comment
Oct 30, 2010. 3:57 PMA-Nuke1979 says:
To make it MUCH easier to remove and replace rubber grips, try using a blower nozzle on an air compressor. Get a little bit of air under the rubber between the controls and the inner end of the grip, then twist and pull off the grip. I did this and it almost makes the rubber slide right over the bar. It also helps to break loose any old glue that's in there when you're taking them off at first.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Code128
Technologist. frog design
