Install Homebrew & MongoDB on a Mac
Published
Introduction: Install Homebrew & MongoDB on a Mac
Installing HOMEBREW and MONGODB on a Mac.
First off what is Homebrew?
Homebrew is the ‘so called’ missing package manager for a Mac. Linux folks who use Redhat and Ubuntu are used to installing things with yum and other package managers. Mac typically installs things with point and click packages because it focuses on the GUI. But this small setup will allow for ease of installation of many packages that are not packaged in a point and click package, in this case we will install MongoDB. (NoSql).
Homebrew is a bit unique from Yum, I would check out the Wiki here and do some reading if you want to learn more.
https://github.com/Homebrew/homebrew/wiki
Ok Lets install Homebrew.
We will use a Ruby call to go the install.
You will need the basics,
• An Intel CPU 1
• OS X 10.5 or higher 2
• Command Line Tools for Xcode: xcode-select --install, https://developer.apple.com/downloads or Xcode 3
• A Bourne-compatible shell for installation (e.g. bash or zsh)
ruby -e "$(curl -fsSL https://raw.github.com/Homebrew/homebrew/go/insta...
It will explain what it is going to do, and then do it for you.
Some simple brew commands.
To update new
-> brew update
To find out what is outdated
-> brew outdated
To upgrade everything
-> brew upgrade
Now everyone is interested in NoSql at the moment, so lets install MongoDB on a mac via Homebrew.
-> brew install mongodb
Here is the output from my terminal
shadowmancer$ brew install mongodb
==> Downloading https://downloads.sf.net/project/machomebrew/Bott...
######################################################################## 100.0%
==> Pouring mongodb-2.6.1.mavericks.bottle.tar.gz
==> Caveats
To have launchd start mongodb at login:
ln -sfv /usr/local/opt/mongodb/*.plist ~/Library/LaunchAgents
Then to load mongodb now:
launchctl load ~/Library/LaunchAgents/homebrew.mxcl.mongodb.plist
Or, if you don't want/need launchctl, you can just run:
mongod --config /usr/local/etc/mongod.conf
==> Summary
? /usr/local/Cellar/mongodb/2.6.1: 17 files, 317M
rapscallion:local shadowmancer$ brew
Example usage:
brew [info | home | options ] [FORMULA...]
brew install FORMULA...
brew uninstall FORMULA...
brew search [foo]
brew list [FORMULA...]
brew update
brew upgrade [FORMULA...]
brew pin/unpin [FORMULA...]
Troubleshooting:
brew doctor
brew install -vd FORMULA
brew [--env | config]
Brewing:
brew create [URL [--no-fetch]]
brew edit [FORMULA...]
open https://github.com/Homebrew/homebrew/wiki/Formula...
Further help:
man brew
brew home
That is it, short and easy. Homebrew will let you install many different things easily, and MongoDB will let you get started with HADOOP!
Homebrew
http://brew.sh
MongoDB
http://www.mongodb.org
Hadoop (Apache)
http://hadoop.apache.org
Thanks
Joseph Murphy
AKA Grehyton (WURM)
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    3 Comments
    Nope you don't pixel67.
    First off, when installing MongoDB from Brew, it will install it into: /usr/local/Cellar/mongodb/3.2.7/
    The configuration file will be located in: /usr/local/etc/mongod.conf
    If you open it up, you'll see that you db directory is specified:
    systemLog:
    destination: file
    path: /usr/local/var/log/mongodb/mongo.log
    logAppend: true
    storage:
    dbPath: /usr/local/var/mongodb
    net:
    bindIp: 127.0.0.1
    Start MongoDB using your configuration file:
    $ mongod --config /usr/local/etc/mongod.conf
    Open a new terminal tab and connect to MongoDB:
    $ mongo
    so when installing from homebrew we don't need to create the /data/db directory?
