Install IJDMTOY 2013-15 Nissan Altima LED Daytime Running Light
967
Published
Introduction: Install IJDMTOY 2013-15 Nissan Altima LED Daytime Running Light
About: Everything about automotive LED lights
Add an elegant touch to your 2013-2015 Nissan Altima by adding this iJDMTOY Switchback LED DRL/Turn Signals for your car! With only a few simple steps you can be on your way turning the heads of onlookers with this amazing new mod for your car!
Step 1:
First, get a flat head screwdriver or pry tool and remove the stock fog lamp bezel or the plastic cover that is located below the original turn signal bulbs.
Step 2:
Remove the original turn signal lamps and put the module box in through the opening.
Step 3:
Install the Nissan Altima LED daytime running lights and plug it into the module box.
Step 4:
To wire, tap the yellow wire to the existing turn signal positive (in this photo, the wire is red). Tap the module box ACC wire to the fuse box and then check to make sure everything is working correctly and enjoy your all new iJDMTOY Nissan Altima LED Daytime Running Lights.
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    2 Comments
    I´m a little confused here. Is this an Instructable or an ad for iJDM products?
    Seems like an ad to me as well. The other instructables are pretty much the same, linking back to the ijdm store.
