Introduction: Install IJDMTOY Ford F250 F350 LED Fog Light
About: Everything about automotive LED lights
The Ford Series F-250 F-350 F-450 trucks are known for their ruggedness and reliability both on the road and off the road. It's no wonder that they are one of the most popular trucks out there to date. For owners who need a bit more lighting on their Ford truck for safety purposes, this Ford F-Series LED Fog Light Kit is a great choice because of the strong lighting output and straightforward installation. After installing this Ford Truck LED Fog Lamp Kit, your huge truck is definitely going to shine like a beacon on the trails.
This guide will show you how to mount the new LED fog lights onto the bracket so your new quad lights will be ready to go.
Step 1:
Remove existing fog light.
Before you do so, loosen the three screws in the back behind the mounting piece to proceed.
Step 2:
Replace with the new LED bracket.
Make sure that the entire LED bracket piece is screwed in behind the mounting piece.
Step 3:
After you make sure the new LED bracket is mounted in place, you can mount your new LED Quad light.
We recommend using a metal bolt since they are heavier, but you can also install the OEM screws that were a part of the factory fog lamp as well.
Step 4:
The mounting process is very straightforward as you can see. This Ford Truck LED Fog Lamp Kit will definitely do your Ford truck justice.
