Install IJDMTOY Truck LED Tailgate Strip Light Bar
5,862
53
Published
Introduction: Install IJDMTOY Truck LED Tailgate Strip Light Bar
About: Everything about automotive LED lights
These are trunk LED tail gate strip lights with 4 functions: on/off brake mode, left turn signal, right turn signal, and reverse mode. This LED strip gives your truck a more kickass appearance to complete the look. It's not every day that you see trucks with some pretty neat LED strip lights so be the first one on the road to have LED tailgate strip lamps! These LED strip lights are universal fit so you don't have to worry about compatibility issues.
Step 1:
Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp. Use soap and water to scrub the area clean since that place is normally dirty.
Step 2:
Carefully measure beforehand where you're going to attach the LED strip so it looks even. The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate so it can be fully universal fit. Take the length of the tail gate and subtract the length of the LED strip.
Quick math lesson! Divide that by 2 to see how much space you will leave per side in order for the entire attachment to be evenly spaced.
Straighten the LED strip and peel adhesive. Please make sure to appropriately apply it once since the adhesive is the strongest the first time it's applied. Firmly apply the LED tailgate strip light.
The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights, but this step is optional!
Step 3:
Tap reverse light wire. You will need to remove either side of the tail light to locate the reverse light. Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
Step 4:
This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
You will find the trailer light connector near the tow hitch.
Step 5:
Hide the wires or zip-tie them. Check the trunk LED tailgate lamp to make sure everything works.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    3 Comments
    Good idea, might have a go, on my Opel, should be cool, a message to HeatherE51 have you checked your wiring on your car what is pos and neg, and have you checked the LEDs to, I recommend using a mltuimeter, if your not sure ?
    I got these lights and the blinkers and brake lights work when my headlights are off but they dont when they are on . Its just a solid red . How do i fix this?
    I thought about this but worried that the LEDs would smash when you opened the tail gate. Thanks for the post!
